My car has been running great. Rebuilt the carb recently, all new wires, plugs, cap and rotor last year. Driving today the car seemed to misfire on the highway and then later on the exit ramp. Got to work, car idles fine. Reved it to 3000 and kept it there - running smooth. So, only things I did not replace were the coil and module last year. I am going to check all wires etc. tomorrow but I have never had a module go bad. Is this a possible symptom? Thanks in advance.
Markus is batting 100%, I too have only seen the modules either work or not.
Go thru the list of things posted above and your bound to find the culprit.
Good Luck
Scott
