1981 cooling issue
Old Sep 23, 2012 | 01:47 PM
bouvie1's Avatar
bouvie1
Default 1981 cooling issue
I have notice that temp gauge nears red line after driving at 70 mph for a long period of time. When I reduce speed it begains to lower temp to 225 degrees.[Any suggestions/solutions appreciated.
Old Sep 23, 2012 | 02:07 PM
briankeery's Avatar
briankeery
Lower rad hose collapsing at speed?
Old Sep 23, 2012 | 02:11 PM
bouvie1's Avatar
bouvie1
Thanks never checked for that possibility,will do on next outing.
Old Sep 23, 2012 | 03:16 PM
SIXFOOTER's Avatar
SIXFOOTER
You are not likely to actually see the hose collapsed, by the time you pull off the road and pop the hood to check it the thing may have gone back to normal looking. When its warmed up good, feel the hose, see if its soft and easy to collapse. There is supposed to be a spring in there to prevent this.
High speed heat can also be the air dam not in place or distorted, and radiator seals missing.
Might be a good time to verify ignition timing also.
Old Sep 25, 2012 | 08:00 AM
bouvie1's Avatar
bouvie1
Default 1981 Cooling issues
Thanks for your input,found timing off 13 degrees and corrected.will follow up on hose and seals.
Old Sep 25, 2012 | 08:34 AM
Street Rat's Avatar
Street Rat
The factory electric fan doesn't turn on until roughly 248. The sensor for the fan can be changed by going to one that turns on earlier. Summit has an abundance of choices. You might try shorting the fan so it runs all the time and see if that cools it down. The lower number temperature sensor fixed the problem on my '81.
Old Sep 25, 2012 | 04:35 PM
bouvie1's Avatar
bouvie1
Default 1981 cooling issues
Thank you for that info on fan/sensor will check that out too. By the way your Pic appears to be the same color as ours "dark metallic"
Old Sep 26, 2012 | 08:03 AM
Street Rat's Avatar
Street Rat
The turn on temp for that sensor is 238 not 248. The fan turns off when the engine reaches approximately 201.
Old Sep 26, 2012 | 09:50 AM
bouvie1's Avatar
bouvie1
Thanks again for that update on sensor,Bouvie1
Old Sep 26, 2012 | 10:15 AM
bouvie1's Avatar
bouvie1
Street Rat could you tell me where to short fan? Thanks Bouvie1
Old Sep 27, 2012 | 10:16 PM
Street Rat's Avatar
Street Rat
I'll send you a detailed pm.
Old Sep 28, 2012 | 01:00 PM
damoroso's Avatar
damoroso
The aux fan doesn't cause high heat and is intended for the exception, not the rule. It also comes on when the AC is on. The problem isn't likely the fan. Is the cap good? Is your lower air dam complete and in place? What about the clutch fan? Is in in place and working properly? Those would be my first suspects....
Old Sep 28, 2012 | 05:05 PM
Street Rat's Avatar
Street Rat
I haven't run my a/c recently. My auxiliary fan still comes on at 200 and shuts off at 185 with the sensor I bought at Summit. It solved my overheating problem when I changed to the new sensor. Not saying this is his problem. Simply giving him something he might want to change. That factory sensor (turn on 238) lets your car get hot before it even triggers the auxiliary fan to turn on.
Old Sep 28, 2012 | 05:33 PM
SIXFOOTER's Avatar
SIXFOOTER
The Aux fan does not come on with the AC on an 81 unless its been modified, it comes on at 238 like posted above. The sensor has 2 contacts that are the switch contacts. This is different than say an idiot light, those have 1 terminal and switches internally to ground.
Kep in mind that the aux fan on an 81 is 31 years old. The technology has improved so much its not even funny. I would take the oportunity to lose the entire engine driven fan and shroud and go straight electric. There are many choices out there, check Summit, Jegs, Speedway etc...
Old Sep 28, 2012 | 07:43 PM
maxmachz's Avatar
maxmachz
Sticky thermostat can cuse issues like this. Cheap to change and rule out.
To 1981 cooling issue
