Timing
Old Oct 27, 2012 | 10:23 PM
billkat's Avatar
billkat
Default Timing
Hope someone here can give me advise. 1972 coupe with 350. Car ran. I marked the distributor and pulled it out. removed points and installed ignitor II. Got it back together and it tried to run but wouldnt. Ended up putting the points back in and putting it on TDC No. 1 and installing the distributor but it just turns over and will not start. have the rotor on the #1 tower.
Old Oct 28, 2012 | 12:29 AM
Ironcross's Avatar
Ironcross
how did you figure the engine is at #1 ......as you must have rolled it over
Old Oct 28, 2012 | 08:25 AM
billkat's Avatar
billkat
I pulled plug in No 1 position and rotated motor to whre I could feel the piston coming up on compresion stroke. Then I got the marks lined up at TDC. Dropped the distributor in with vacuum advance facing the proper position. Had rotor on the No 1 tower on the cap. I know it has to be timing. The care strted no problem before I did anything.
Old Oct 28, 2012 | 08:29 AM
69small block's Avatar
69small block
Default timing
where is rotor pointing needs to point at # 1 piston
Old Oct 28, 2012 | 08:50 AM
billkat's Avatar
billkat
I had the rotor at No 1 position. I am going to pull the distributor again and check the oil pump drive shaft. IT looks like the rotor is between No 1 and No 8 tower.
Old Oct 28, 2012 | 10:12 AM
myko's Avatar
myko
Start with the very basic stuff first. I'm sure you did but recheck once more. I built an engine a couple of years ago and on my first start to break in the cam.... nothing. I cranked on it for two days before I realized that I had put the plug wires on the dizzy in reverse order! I'm still waiting for the cam to wipe a lobe!
Old Oct 28, 2012 | 10:52 AM
69small block
Default timing
piston not position on dist. cap you could have engine on #6 tdc easy to do. I had my dist. 180 out on first start up also. ck yhey basic stuff first. as myko stated easy to get turned around
Old Oct 28, 2012 | 12:13 PM
lars's Avatar
lars
I have a complete paper with photos on distributor installation, if you need it. Simply e-mail me a request for a copy.
Lars
V8FastCars@msn.com
Old Oct 28, 2012 | 12:30 PM
billkat's Avatar
billkat
On the rotor cap the #1 tower points toward around the no. 4 piston. I have the rotor on the no. tower in the cap. The coil is putting out spartk but no spark at plugs.
Old Oct 28, 2012 | 01:24 PM
diehrd's Avatar
diehrd
Are you sure it was on the compression stroke ?
Old Oct 28, 2012 | 02:44 PM
my 76 ray's Avatar
my 76 ray
If you are saying that you have no spark to the spark plug wires, you should check to make sure you don't have the wire to the points or condenser grounded on the distributor body. That will prevent spark from getting to the spark plug wires.
If you do have spark to the spark plug wires, then I would try to find top dead center again and restab the distributor. It seems like my rotor pointed to #6 when I installed it.
Old Oct 28, 2012 | 03:52 PM
billkat's Avatar
billkat
Thank you for all the replies and info. I took everything out and put it all back in again and shes running now. Thanks again all, Bill
To Timing
