Rams Horn Improvement?
Old Nov 4, 2012 | 11:21 AM
Taijutsu's Avatar
Taijutsu
Default Rams Horn Improvement?
I was going to order up some 2.5" RHs to replace my 2" smoggers.
I noticed these while browsing.
http://www.speedwaymotors.com/Tru-Ra...olds,3823.html
These are obviously a little different.
Can anyone take a guess on how they will fit on my 74?
If they are not an improvement, I will go w/2.5 stk
and do a little grinding before I put them on.
TIA
R
Old Nov 4, 2012 | 01:18 PM
7T1vette's Avatar
7T1vette
I would go with the 2.5" factory manifolds, so that it will still 'look' stock. But, if the 'stock look' isn't that important to you, that looks like nice set.
Old Nov 4, 2012 | 01:40 PM
speedreed8's Avatar
speedreed8
there's also these from McJacks
http://www.vetteheaders.com/servlet/...rvette+Headers
Old Nov 4, 2012 | 04:05 PM
Taijutsu's Avatar
Taijutsu
Default Port Size?
Does anyone know the size of 2.5" RHs?
How do they compare w/specs of the 1.375" True Rams?
I want to at least open up the RHs to match my TFS heads.
Then I'm off to the dyno. LOL
Old Nov 4, 2012 | 05:21 PM
jb78L-82's Avatar
jb78L-82
McJacks:
Old Nov 4, 2012 | 08:56 PM
DucatiDon's Avatar
DucatiDon
C2 of Year Finalist (performance mods) 2019
2018 C2 of Year Finalist
+1 for McJacks.....
Old Nov 5, 2012 | 07:34 AM
71scgc's Avatar
71scgc
+2 for McJacks
Old Nov 5, 2012 | 09:26 AM
oldalaskaman's Avatar
oldalaskaman
it would be good to find out if they had any clearance issues, ac compressor/alt./heater/acbox, they may cook those, but they look good
Old Nov 5, 2012 | 10:11 AM
2Quickrides's Avatar
2Quickrides
If you're set on the stock look of manifolds, look into some of the circle track stock car engine builders. Quite a few make good power through either manual or acid ported ones. Still not as much flow as headers, but the best you'll get with manifolds for sure.
Old Nov 5, 2012 | 11:01 AM
gcusmano74's Avatar
gcusmano74
By 1974, the stock ram's horn manifolds had 2" outlets. The early 327's had a 2 1/2" outlet. But I think Chevrolet changed to a 2" by 1967 or so.
Old Nov 5, 2012 | 11:15 AM
tfi racing's Avatar
tfi racing
For those who like to waste a pile of money for very little gain...
http://www.castheads.com/corvette_systems.php
Old Nov 5, 2012 | 01:46 PM
2Quickrides
Not saying I would ever do it. Lol. Headers are one of the first mods I do to EVERYTHING.
Old Nov 6, 2012 | 10:10 AM
Taijutsu's Avatar
Taijutsu
Default Best Bang for the Buck!
I think that going from the 2" RHs to the stk 2.5" RHs will be my best bang for the buck.
Since they will be a straight swap w/old RH, no fabrication will be needed.
I have heard stories about how hard the RH gets after years of heat/cooling cycles. I would like to open these up a bit, perhaps with
a sharp stone ofsome kind. No carbide cutters available.
Now the only question is: How much HP/TQ will I gain?
Any thoughts?
R
Old Nov 6, 2012 | 12:26 PM
redman76's Avatar
redman76
St. Jude Donor '09
What size is the rest of your exhaust system?
Old Nov 6, 2012 | 05:21 PM
Taijutsu's Avatar
Taijutsu
My 74 has stk 2.25" duals, w/ H-pipe added.
Stk cheap mufflers too!
To Rams Horn Improvement?
