"normal" vacuum readings?
Old Nov 27, 2012 | 09:38 AM
MonteHall's Avatar
MonteHall
Cruise-In VII Veteran
St. Donor '03 & '06
Default "normal" vacuum readings?
I have a carb converted 84. carb is a big bore qjet (I forget the casting number, but it's off of a 75 vette) engine is otherwise stock, except the cats are gone and I'm running stright pipes with aftermarket mufflers.
it's running rich, and you can smell it when behind the car.
on my vac gauge, I'm getting 20 inches at idle, with a slight (1 in) variation at a regular interval.
I'm guessing that's a fairly normal reading?
or is the odor due to the lack of cats?
Old Nov 27, 2012 | 09:46 AM
lars's Avatar
lars
For a stock engine with a stock cam that's a "normal" reading. Depending on cam and engine configuration, "normal" can cover quite a range.
The '75 Q-Jet is not a "big-bore" carb. It's the standard 750 cfm Q-Jet, and it will usually run lean unless there is some setup issue with carb or timing. Be sure to set the timing up correctly per my timing papers, and then you can tune the carb per the "Quickie Performance Setup" guidelines in my Q-Jet Setup paper. Both papers available by e-mail request if you need them.
Lars
V8FastCars@msn.com
Old Nov 27, 2012 | 10:30 AM
MonteHall's Avatar
MonteHall
St. Donor '03 & '06
Lars
V8FastCars@msn.com
The carb has the hump in the primary.
isn't that indicitive of the larger bore qjets?
casting number is 7045223
Old Nov 27, 2012 | 12:50 PM
MrForce's Avatar
MrForce
St. Jude Donor '11, '14
Has the distributor been changed from computer controlled to mechanical advance?
Old Nov 27, 2012 | 01:06 PM
MonteHall's Avatar
MonteHall
St. Donor '03 & '06
yeah, vacuum advance HEI.
Old Nov 27, 2012 | 01:19 PM
lars's Avatar
lars
If the venturi has a small bulge at the 2 o'clock position in the driver's side primary (as viewed from the front of the carb) and 10 o'clock on the passenger side, then it's the 800 cfm carb. I've never seen an 800 cfm '75 Chevy passenger car carb.
Lars
Old Nov 27, 2012 | 03:53 PM
scottyp99's Avatar
scottyp99
http://www.youtube.com/watch?v=xuqz5Bs96Tw
Dig the redneck accent! Be patient, the guy takes 4 minutes and 35 seconds to show us something that should take about 30 seconds, tops.
Keep the shiny side up!
Scott
Old Nov 28, 2012 | 10:07 AM
lars's Avatar
lars
His video clearly shows the small bulge at the positions I indicated above. Note also that the 800 cfm carb he has is a Pontiac - not a Chevy. The Chevy 800's are very uncommon, and I don't think the '75 passenger car carb was a big carb. I'm going to check one of my spares to verify that, so I may stand corrected... I just checked a '77 Vette carb, and it's a 750..
Lars
To "normal" vacuum readings?
