spark plugs
Old Jan 16, 2013 | 04:31 AM
tobyj7's Avatar
tobyj7
Default spark plugs
my mechanic told me (while he was doing my wheel bearings) that my 73 is starting up on 7 cylinders then when it warms up goes on all 8.
his quick fix solution was to try and replace the spark plugs with the next firing size. i currently have champion BL - 11Y
what should i try with the new ones or should i not be doing this?
Old Jan 16, 2013 | 04:34 AM
tobyj7's Avatar
tobyj7
its a 350 base engine
Old Jan 16, 2013 | 05:47 AM
Belgian1979vette's Avatar
Belgian1979vette
Has nothing to do with spark plugs, unless the gap is closed up on that one cyl.
Old Jan 16, 2013 | 06:40 AM
scottw's Avatar
scottw
Take a timing light, hook it up to the non-firing cylinder and see if you are getting power to that plug wire. If you are, it is either not fully seated on the spark plug or your plug needs to be replaced. If you are getting no power to that one wire, start looking back to the dizzy. Maybe the wire is not seated on the cap.
Old Jan 16, 2013 | 07:15 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Get rid of the Champions and replace with the AC Rapidfire #2's.
Old Jan 16, 2013 | 10:20 AM
Peterbuilt's Avatar
Peterbuilt
Default What!
Really?
Did he say how that can happen?
You might need a new mechanic.
Old Jan 16, 2013 | 10:33 AM
Mike Ward's Avatar
Mike Ward
Originally Posted by petes74ttop
Really?
I can think of at least two scenarios where that cans and does happen, but putting a hotter plug is not the cure.
Old Jan 16, 2013 | 11:09 AM
Peterbuilt's Avatar
Peterbuilt
Default OK tell me more.
What is the cause and the cure?
Old Jan 16, 2013 | 11:11 AM
7T1vette's Avatar
7T1vette
If he was any good, he would have isolated which plug it was, removed it to check whether it was the plug or not, also checked the wire to that plug and the distributor cap.
Since he didn't do any of that, he's probably just "stumping" for more business...
Old Jan 16, 2013 | 12:07 PM
MelWff's Avatar
MelWff
I cannt find any cross reference from the stock plug, AC Delco R44T, to a Champion BL11Y. The nearest plug would be a BL13Y which is a R45T.
Old Jan 16, 2013 | 01:57 PM
Belgian1979vette
Measure resistance of your wires. Should all be in the same range. I just had the same thing happening on the startup of a new engine. Ran really rough, explosions in the exhaust and such. Took the plugs out, no problem. Took the wires off and measured them. One was broken.
Old Jan 16, 2013 | 02:38 PM
tobyj7's Avatar
tobyj7
ill check all the wires and plugs today and see how i go. he was fixing something else and i didnt want him to start looking into this just to save money
Old Jan 16, 2013 | 03:14 PM
Mike Ward's Avatar
Mike Ward
Unless he told you which cyl. is not firing, pull all the plugs and look for one that's rusty or crudded up.
Old Jan 16, 2013 | 07:28 PM
tobyj7's Avatar
tobyj7
Cheers guys I might post some pics tonight of what I find. (Australian time)
Old Jan 17, 2013 | 04:11 AM
tobyj7's Avatar
tobyj7
so i took each cable off the distributor and they all looked good, checked all sparkplugs and they all seemed good. put it all back together and its running fine.
Old Jan 17, 2013 | 01:34 PM
cottoneg's Avatar
cottoneg
Sort of related to you topic, I have found Champion spark plugs did not work well for me. After a day at the track, they need to be replaced. After a few brands I now use NGK spark plugs. You may want to consider giving them a try.
Old Jan 19, 2013 | 11:34 AM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
When I installed the AFR 195's I put in Rapidfire # 5's. They eventually took on a nice tan colour but the engine took a while to smooth out at idle. I then put in the NGK's. The engine smooth's out much quicker on warm up and seems to run better. The plugs are now white vice tan with no other changes to the engine.
To spark plugs
