carburation manifold info request
Old Jan 26, 2013 | 02:00 PM
haydenray's Avatar
haydenray
Default carburation manifold info request
Hi
This is my first attempt at this so bear with me. I just purchased a '74 T Top. The car came with an amazing collection of upkeep receipts showing routine maintenance including a carburator rebuild from the first owner. The second owner bought it from a dealer after trade in. She only did fluid service for the twelve years she had it. I have discovered it has an Edelbrock 1902 carburator 750cfm and a GM 340281 intake manifold. I have found that this was used 82 to 85 on Camaros. I can't find out whether or not is a higher rise than the stock intake from 1974.
Anyone know if it is a higher performance manifold and what does it do to engine performance. The engine is the standard 195 hp as far as I can tell, though I can't see the engine number under the compressor. Other threads have indicated that this is a higher than neessary carburator. I would appreciate anything I can find out. I suspect the dealer put these on as I can't find a receipt.
Thanks,
Ray.
Old Jan 26, 2013 | 05:22 PM
Street Rat's Avatar
Street Rat
I had an 82 Z28 Camaro. It had throttle body injection from the factory. Not a carburetor and regular intake. You can search that manifold number on the internet and find more info. Good luck.
Old Jan 26, 2013 | 07:53 PM
Mike Ward's Avatar
Mike Ward
I'd bet that the number is 340261. Sixes can look like eights. This is the stock manifold for a '74.
Your carburetor is a step backwards in technology from the orignal Qjet, but it's not too big. The original was a 750 cfm also.
Old Jan 27, 2013 | 12:07 AM
WHITE 1974's Avatar
WHITE 1974
You should be able to read the casting number on the block even with the compressor there.I have a 74ac car ,I used a flashlight and magnifying glass if the code is J its the base L48 I to have the edelbrock carb that I inherited from the previous owner mine is a 600 works really well but I wish he left the quadrajet there
Old Jan 27, 2013 | 12:53 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Performance is Ok with those manifolds but not a high rise.
There were no aluminum intakes for the sb chevy in the mid 70's. An 80's camaro alum intake swap is a good choice to get a factory GM alum intake.
The only stock sb "high rise" was on the late 60's and early 70's LT1's. These were for square bore Holley carbs and would not fit your "spread bore" quadrajet. But GM performance still sells an cast iron "LT1" intake that with fit both spreadbore and squarebore carbs if u are interested and yes this would be an performance improvement though weight several pounds more.
Have fun,
cardo0
Old Jan 27, 2013 | 11:56 AM
7T1vette's Avatar
7T1vette
The Edelbrock #1902 is a suitable replacement for the original Quadra-Jet carb. #1902 is a Q-Jet from Edelbrock after Rochester sold the equipment and the rights to that carb to them. It may not be identical to what was there from the factory, but the basic carb is the same.
Old Jan 27, 2013 | 01:02 PM
haydenray's Avatar
haydenray
Thanks for the responses. The number is definitely a 340281, just rechecked the photo.
The internet says the 61 is a low rise, but nothing about the 81. I'm glad the carb is close to stock. I have dynomometer results from the first owner that show poor gas feed to several cylinders. The car has a lot more low end grunt than my L82. I don't have any experience with the L48.
Ray
Old Jan 27, 2013 | 02:19 PM
birdsmith's Avatar
birdsmith
C3 Corvettes of all years came with low-rise intakes NOT because GM wanted to restrict output but because there wasn't adequate hood clearance. The big block cars and LT1's were exceptions, but typically that is the limiting factor with these cars-if you want to open up your options here you need a hood with a little more clearance.
Old Jan 27, 2013 | 08:50 PM
haydenray's Avatar
haydenray
Thanks again,
Located engine casting numbers and they are appropriate to the car so I assume that the carb and manifold are the only non stock components. I appreciate the input.
Ray
To carburation manifold info request
