Power steering valve - spring order
Old Feb 18, 2013 | 12:45 PM
Mooser's Avatar
Mooser
Default Power steering valve - spring order
Putting my steering valve back together (basic clean and inspect) and noticed the one area seems backwards to the manual and the way I'd expect.
Found a thread and this seems to match what I was expecting
The smaller spool (2nd one from left)
c-clip retainer
larger spring
seal retainer
seal
flat washer
The way it was on when I took it apart
c-clip
seal and retainer
flat washer
spring
Just looking for anyone just verify before I button this up?
Mooser
(sometimes I wonder how this car every moved)
Old Feb 18, 2013 | 12:50 PM
oldalaskaman's Avatar
oldalaskaman
wilcox has a pretty excellent video on rebuilding this, I rebuilt mine but its been ...awhile.
Old Feb 18, 2013 | 01:07 PM
7T1vette's Avatar
7T1vette
Send a PM to Jim_Shea. He is the resident expert on these matters; he worked at Saginaw Steering for years and knows this stuff inside and out. He also has lots of documentation on rebuilding the steering components. I would not put it back together without getting the correct info from him.
Old Feb 18, 2013 | 01:08 PM
Mooser's Avatar
Mooser
I'm wading my way through Jim Shea's white pages now, I'll check wilcox's site also
Mooser
Old Feb 18, 2013 | 01:50 PM
4SPDL81's Avatar
4SPDL81
St. Jude Donor '16
One of Jim Shea's pwr. strg. cntl. valve paper's notes that the GM instruction is incorrect and shows the correct order of assembly....good luck!
Old Feb 18, 2013 | 03:00 PM
Mooser's Avatar
Mooser
Got it all back together correctly (Jims' papers also explained that the o-ring in the manual isn't there, that helps)
Does anyone know how hard it should be to activate the valve?
I'm guessing you shouldn't be able to really move the ball-stud by hand based on the springs and how much resistance there must be on the car.
Just curious I guess
Mooser
Old Feb 18, 2013 | 04:10 PM
jim-81's Avatar
jim-81
Mooser -
How hard a job is this? I am considering doing it too. I have seen the video on Willcox's site. What rebuild kit did you get?
Thanks, Jim
Old Feb 18, 2013 | 05:32 PM
Mooser's Avatar
Mooser
Originally Posted by jim-81
Mooser -
Thanks, Jim
Remarkably easy... once I got the order of the springs/seals correct.
I used the C-central kit. (minor kit 562337 basically new seals since everything else seemed fine)
All in, less than 1/2 hour (minus all the research time)
Mooser
Old Feb 18, 2013 | 06:54 PM
71scgc's Avatar
71scgc
CSSB has a good tutorial on PS valve rebuild on their website. It's what I used on mine.
My valve was pretty stiff after the rebuild, and I wondered if I had done it right too. Installed it, and it worked fine.
Hardest part of rebuild? Getting the two halves pressed back together without tearing your work up!
Carter
Old Feb 19, 2013 | 08:21 AM
jim-81's Avatar
jim-81
After watching Willcox's video a couple times, yeah, it doesn't look too bad. I think I'll try it.
Old Feb 19, 2013 | 01:12 PM
Mooser's Avatar
Mooser
Carter
I'd second that.
After fighting with it a few times I polished the chamfer leading into the bore and made sure the transition was extra smooth. Lots of jelly on the seal and fingers crossed it went together nicely
Mooser
To Power steering valve - spring order
