Warbonnet yellow paint
Old Feb 20, 2013 | 06:43 PM
blade072's Avatar
blade072
Default Warbonnet yellow paint
I have a 1972 LT1 that I am restoring. I am getting ready to paint the original color of warbonnet yellow.
I would like this paint to match the original paint color as close as possible.
Any suggestions in terms of paint numbers etc.
You input will be appreciated.
Jim
Old Feb 20, 2013 | 06:52 PM
birdsmith's Avatar
birdsmith
Typically you would go to an automotive paint vendor; the paint code would appear on the trim tag in the front driver's door sill. Give your vendor that code and he can mix the paint to that specification.
In lieu of that, he should have catalogs listing all the factory paint codes and can mix the paint using that as a guide. Have fun with the painting!
Old Feb 20, 2013 | 07:14 PM
JLinCA's Avatar
JLinCA
Jim
Hi,
According to the Corvette Black Book, the code for WY is 989.
Old Feb 20, 2013 | 07:39 PM
7T1vette's Avatar
7T1vette
Two other important questions are:
What type of paint do you want to use? and What brand of paint do you want to use?
Old Feb 20, 2013 | 11:04 PM
blade072's Avatar
blade072
I would like to use a Base Coat Clear Coat.
I was hoping someone would tell me what they used.
Old Feb 21, 2013 | 05:54 AM
Danish Shark's Avatar
Danish Shark
Isn't there a "hidden" spot that still has the original paint? Like under the door sill plates or under the tail lights?
The color will still be fresh and can be scanned and recreated.
Old Feb 21, 2013 | 09:38 AM
7t9l82's Avatar
7t9l82
PPG has always been good for me.
Old Feb 21, 2013 | 09:53 AM
blade072's Avatar
blade072
Thanks,
I will also use PPG. Just met with the paint store and they can formulate for warbonnet yellow and 989 paint code.
Old Feb 21, 2013 | 10:06 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Original codes here: http://www.corvettepaintcodes.com/ Your paint supplier should be able to use the old codes to match new formula paint for you.
You can also take a painted part to your paint supplier and they can "scan" it for a match. Fuel door would be the easiest to take with you when you go.
Old Feb 21, 2013 | 10:42 AM
7T1vette's Avatar
7T1vette
In that era, GM/Chevrolet had a 'FireMist' option on some of the paint colors. Those paints were the same color, but had a higher metallic content and the metalflakes were larger, I think. I know that Ontario Orange was one of the FireMist option colors; curious about whether the War Bonnet Yellow was one, also. I always liked that color, but it just seemed faded-out, for some reason. If it was made a FireMist color, that would really make it "pop".
Old Feb 21, 2013 | 04:43 PM
Alan 71's Avatar
Alan 71
Hi,
My understanding is a bit different than 7T1's concerning FireMist colors.
In 71 three of the 7 new colors were described as "special "fire mist" hues". These colors were Steel Cities Gray, Ontario Orange, and War Bonnet Yellow.
There was no "optional" level of metallic involved with these three colors. Each was available in just one formula and paint code.
Regards,
Alan
Old Feb 21, 2013 | 04:52 PM
redrdstr72's Avatar
redrdstr72
Originally Posted by Alan 71
Hi,
Regards,
Alan
Listen to Alan. As always, he's right.
Old Feb 21, 2013 | 08:42 PM
7T1vette's Avatar
7T1vette
That's not my understanding, Alan. I've seen the Ontario Orange in the 'standard' version and in the FireMist version. The hue is the same, but the appearance is quite different. Maybe others can chime in on the FireMist issue.
Old Feb 21, 2013 | 09:49 PM
redrdstr72's Avatar
redrdstr72
7T1: I wonder if the different hues you've seen are due to variations in re-paint color matches? My research yields what Alan suggested. There were 3 "Firemist" colors included for 1972. The "Firemist" colors were Steel Cities Gray, War Bonnet Yellow and Ontario Orange. According to Mike Antonick's Corvette Black Book, production paint offerings were as follows:
Code Name/Description
912 Sunflower Yellow
924 Pewter Silver
945 Bryar Blue
946 Elkhart Green
972 Classic White
973 Mille Miglia Red
979 Targa Blue
987 Ontario Orange
988 Steel Cities Gray
989 War Bonnet Yellow
There are no optional paint finishes mentioned.
Seems to me that the 3 colors carrying the Firemist classification had more/larger metal flake than the traditional metallic colors. If a car was re-painted in a Firemist color but with a more traditional metallic finish (smaller flakes), it might look different than the original finish.
Old Feb 22, 2013 | 10:19 AM
7T1vette's Avatar
7T1vette
The 'standard' Ontario Orange had a very fine metalflake, similar to that of Bridgehampton Blue. But the FireMist OO had a denser, larger metalflake that really popped in the sun. If those three colors were always applied as FireMist colors, perhaps the 'standard' colors I've seen were re-paints done with too little metalflake???
Old Feb 22, 2013 | 05:38 PM
mjf6175's Avatar
mjf6175
As someone who ordered a 1971 Corvette coupe new from the dealer (good God I am getting old) I can safely say that Alan was correct as to the three "firemist" colors: Ontario Orange (which I ordered); Steel Cities Gray; and War Bonnet Yellow (my second choice). There was NO additional charge for these colors. There was also no "second" Ontario Orange that had less (or no) metalflake. And these three were the only colors that were "firemist". I believe I know where some of the confusion comes over getting the same color with no metalflake. If I remember correctly, in 1976 there was a color VERY similar to Ontario Orange but was NOT firemist and had no metalflake. Don't have my books in front of me to check, I am sure someone else on here can look up the colors available for 1976, believe it was called "Orange Flame" (damn I am old, can't remember either!).
Old Feb 22, 2013 | 06:01 PM
7t9l82's Avatar
7t9l82
not to nit pick but, someone used the term " metalflake". chevrolet , and i don't think any car company ever used " metalflake" . they used "metallic" paint. and if you have ever seen a real metalflake paint job you know there is a big difference.
To Warbonnet yellow paint
Old Feb 22, 2013 | 07:44 PM
7T1vette's Avatar
7T1vette
The difference is only in the size and quantity of the metallic particles in the paint. And, you are correct that Chevy generally used a very fine metallic element in their metallic paints. The "FireMist" colors are probably the exception to their normal practice.
I stand corrected on the manner in which Chevy implemented their FireMist paint colors. Thanks for the 'education'.
Old Sep 28, 2024 | 11:53 AM
Tejkos's Avatar
Tejkos
Cruising
Can someone tell the international "RAL" color code that would be closest to "Warbonnet yellow 989"?
Maybe someone has already checked it or could check it with actual RAL color samples stack.
Old Sep 29, 2024 | 12:33 PM
vettebuyer6369's Avatar
vettebuyer6369
You are tacking a question onto a post thats been dead for 11 years. Please start a new thread with your question.
