Dyno test predictions
Another example of a 78 L-82 4 speed on the same dyno with 100,000 miles on the dyno and compression of 140-145 PSI with 2.5 inch magna flow mufflers, OEM cast iron exhaust manifolds, edelbrock performer intake, OEM Q-jet, and a cam of unknown origin, no pollution control, and an open paper air cleaner resulted in 248 RWHP-Form member Karol.
Hope that helps!
If your $hit can't live on a dyno, it damn sure isn't gonna live on the drag strip.. The load is not nearly the same on an inertia dyno compared to real street/track passes... A dyno pull will only last a few seconds... The more power the car makes, the quicker the pull will go.
Eddy current dynos like a Mustang Dyno can/will load the engine a lot hard with the Dyno brake... It's definitely harder on the engine then an inertia dyno...
That being said, I once made 47 pulls in one day on my turbo bike tuning... Just keep the heat down and don't make hot pulls..
I made 10 pulls in one day in my Z06, all of them over 800rwhp and on pump gas/meth... No issues at all.
To the OP, 218rwhp is pretty decent numbers for a stock '74 350.. My stock '71 350 with an L79 cam and headers only made 205rwhp.. That was with no air cleaner and hood open.. Thru a t400.
That being said they can also be set up to give about any number you want. Ever notice dyno operators almost always ask how much you think your car will make? That could be for setting the peramaters but then it could also be to make the customer happy. Always tell them you have no idea.
My friend has a properly calibrated chasiss dyno, took a few months of phone calls between him and the manufacturer before it finally gave the correct RWHP. He told me he had a Viper day and he said you should have seen all the long faces to point where some of them said the dyno wasn't working properly, they couldn't take the reality of there big bad vipers making way less than they they thought in the bars.
