Dyno predictions
Old Mar 30, 2013 | 08:13 AM
aaroncorvette's Avatar
aaroncorvette
I got these from Dynolicious
Acceleration
0-10 MPH: 1.02 sec
0-20 MPH: 1.74 sec
0-30 MPH: 2.40 sec
0-40 MPH: 3.06 sec
0-50 MPH: 4.14 sec
0-60 MPH: 4.79 sec
0-70 MPH: 5.46 sec
0-80 MPH: 7.01 sec
0-90 MPH: 8.96 sec
0-100 MPH: 10.67 sec
Elapsed Time
60': 2.57 sec @ 30.5 MPH
330': 5.93 sec @ 74.5 MPH
1/8 mi: 8.67 sec @ 86.8 MPH
1000': 11.08 sec @ 101.7 MPH
1/4 mi: 13.08 sec @ 113.9 MPH
Miscellaneous
Max Speed: 114.8 MPH
Max Acceleration: 0.73 G's
Peak Horsepower: 425 HP
It wasn't the best start as the ground was dusty, although I think these times are a tad optimistic
Old Mar 30, 2013 | 10:28 AM
L-82kid's Avatar
L-82kid
Originally Posted by aaroncorvette
What does a stock '02 Z put out? As I raced one and he wasn't getting away from me.
C5 z06 stock usually make like 320-330rwhp, but every car is different. I saw a bone stock c5 z06 put down 344rwhp at my buddy shop.
stock Ls1 SS camaros make around 270-300rwhp. You will probably be around that range.
Are you running the Edel RPM camshaft too? .488/.510 234/244 112lsa?
Old Mar 30, 2013 | 10:33 AM
aaroncorvette
Cheers, yeah that's the cam
Although it's getting replaced with a Crower 00425 late this year
http://www.summitracing.com/parts/cro-00425
I already have the cam, just need to source the other parts
Old Mar 30, 2013 | 10:52 AM
aaroncorvette
Any ideas on what I expect to gain with this cam?
Product Type Mechanical Roller
Valve Lash .026" intake and .028" exhaust
Lobe center 112
Advertised Duration: Intake / Exhaust 280 / 288
Duration @ .050" Lift: Intake / Exhaust 246 / 248
Lobe Lift: Intake / Exhaust .369 / .378
Rocker Ratio: Intake / Exhaust 1.5 / 1.5
Gross Valve Lift: Intake / Exhaust .554 / .567
Old Mar 30, 2013 | 11:15 AM
SuperBuickGuy's Avatar
SuperBuickGuy
somewhere between 260 and 300
Old Mar 30, 2013 | 12:44 PM
HBZ_81_C3's Avatar
HBZ_81_C3
Yeah, i'm not sure where Edelbrock gets 420hp from??
The RPM heads will make some power!
Old Mar 30, 2013 | 03:43 PM
aaroncorvette
Yeah, I really like Edelbrock's products.
Old Mar 30, 2013 | 04:03 PM
HBZ_81_C3's Avatar
HBZ_81_C3
With just a little work on them they flow really nice. I've got a set on mine. I've gone through a couple of different cams and intakes on them. Finally settled on a Victor Jr. Intake with a 1 1/4" spacer (Wilson nitrous plate) and a Bullet cam. I'm pretty happy with the performance.
The car is wicked fast if you need it to be. I have no idea as to HP numbers for it, but have been 140+ on occasion at the track. Now granted that is with the help of a small shot.
Old Mar 30, 2013 | 05:39 PM
aaroncorvette
Nice info, yeah I was talking to Dad the other day saying the vette doesn't need to be any faster really, it's got just enough power for the chassis, any more and it'd be a bit scary I think without a rollcage to stiffen it up.
Oh, and nice burnout pic.
Old Mar 30, 2013 | 07:57 PM
HBZ_81_C3's Avatar
HBZ_81_C3
Thanks, that pice was from Drag Week 2009 at Summit Motorsports Park in Norwalk.
No more cage in mine. The 8 point is cut out and in pieces in the floor. Totally new interrior and can't even tell it was ever there. It was kind of a waste since it was only in for a couple years. Door bars for even less time. Turning it into just a nice but quick street car. I accomplished what I set out to do with it. No more obstruction inside with the bars! Even with swing out door bars it was still a pain in the a$$.
Leaving the engine as is. I can go plenty fast enough on motor alone to get kicked out of any track at will. Nitrous is staying on as well more so as a carb spacer than else and to play with all the kids around here with their blue oval Mustythangs!!!
Here is the power plant in the '81.
And if I feel the need for speed, I play with these!
X275 Drag Radial. 565 BBC on one BIG kit. Probably close to 600 on the spray. Steve Schmidt built piece.
'69 Bickel built Camaro ProMod. 540 Musi BBC with twin 88's.
Best to date on the ProMod.
Old Mar 30, 2013 | 08:34 PM
lance m p's Avatar
lance m p
Default Not at ALL trying to be a ............>
Originally Posted by MotorHead
265RWHP since I have no idea what the motor is. It's not that easy to 300RWHP out of a street driven 350ci engine
"horses-behind" however it completely escapes me why? it seems so hard to get 300rwhp on the street? w/no NOS either. I don't do this for a living. My 1st 5-6 SBC's were uderwhelming......to say the least in the late 70's early 80's. Well I found out for> ME that my main problem was the hear this read that thing? And then my 2nd problem was mismatching parts....under/over-cammed/wrong compression/too big of a carb/wrong heads...etc. Well w/comparitivily inexpensive, WELL matched components and a few little tricks here and there and I found my last 7-12 SBC's 350-355cid's easily gave me 300 + at the drives...and no big rumpity cam either or compression so high you had to run 110 in it on the street. It just seems too easy now, especially w/the tech we have available Now at a realitively young age [55] MS is slowly crippling me so I have 2 left and all the components matched and all assembled. So my building days are over. I took my time on these last 2, #1 is a 355cid SB going in my 82 Vette and #2 is a 231cid 0.30=235cid V-6 Turbocharged/Aftercooled Buick [had that one down 3 times] And nope I won't get 300+rwhp on this last SBC...why? I'm staying w/the stock albeit HEAVLY ported crossfire intake-I'm not delusional. Besides I already know the flywheel hp on both, at the drives the 355cid will be 270-278rwhp [using a 25% reduction from flywheel to drives] with the STOCK intake on it. race-on.....and good luck!
Old Jun 29, 2021 | 05:11 PM
aaroncorvette
Originally Posted by DucatiDon
My AFR headed Roller cammed L82 made 260 rwhp at 4500 rpm....SO id guess your is likely a smidge less. Id guess >closes eyes< 300rwhp @6500 rpm.
Will you share a dyno run and put our guesses to shame?
Hi Don
It made around 280rwhp on the dyno in the end. The engine then exploded a short while later!
sorry it’s taken 7 odd years to reply....
the car now has a 383 with a Comp Cam flat tappet XE284H Will upgrade to a roller at some point
Old Jun 29, 2021 | 05:51 PM
  #33
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Nice machine! My buddy has a 959 Musi motor with Musi twin TBs with four kits. STUPID amounts of HP out of that motor. Somewhere in the 4000-4500hp range. GL with yours.
Old Jun 30, 2021 | 03:59 PM
  #34
vettebuyer6369's Avatar
vettebuyer6369
He hasnt logged on in over a year, so he might not see the message.
Hi Don
I guess the thread is now complete.
Start a new thread with reports on upgrades!
