Distributor question
Old Apr 10, 2013 | 11:32 PM
La Changa-Reub's Avatar
La Changa-Reub
7th Gear
Default Distributor question
I am almost done with my 350 off my '72 mild street
Build but need a distributor and looking for
Advice on which one with price $400 or less. I have
A mother thumper cam kit,roller lifters,aluminum
Trick flow super 23heads, air gap intake,600 Cfm
Carb,110 gph eldelbrock fuel pump, just for idea
Of my build but am actually a little lost on what to
do with ignition. Was looking at msd but saw
For corvette had separate system n big price
Difference I have mechanical tach drive
Any help appreciated
Old Apr 10, 2013 | 11:48 PM
TimAT's Avatar
TimAT
Unless you're stuck on one brand or another, there are HEI's out there with tach drives. I have an MSD mag pickup distributor with tach drive and using the original TI amplifier and coil with it. Works better than the MSD distributor with a Summit brand box.
The tach drive runs the price up too. I just got a complete HEI for another project (no tach drive) for $80 out the door.
Old Apr 11, 2013 | 07:05 AM
Iron_dog's Avatar
Iron_dog
If you have the stock one, I would consider a rebuilding and upgrading with Pertronix3 module to get rid of the points...
Old Apr 11, 2013 | 10:28 AM
Mike Ward's Avatar
Mike Ward
What's wrong with your existing distributor? An aftermarket unit will not get you any more HP.
Old Apr 11, 2013 | 10:33 AM
lars's Avatar
lars
A properly set up stock distributor will run as well as, or better than, anything available aftermarket on a mild street engine such as yours.
Lars
Old Apr 11, 2013 | 10:50 AM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
The stock distributor is fine - rebuild it if needed; recurve it if desired. My stock corvette distributor is still used in my '65 which ran low 11s. What's not to like?
Old Apr 11, 2013 | 02:07 PM
glackore's Avatar
glackore
Choosing to keep your stock distributor is a good idea. You can keep the points in it or replace them with a Unilite or Pertronix set-up.
Choosing an aftermarket distributor offers a vast array of options. Adding a mechanical tach drive to it adds to the cost. Me, I run a Mallory Unilte mechanical advance and mechanical tach drive distributor. It is very maintenance free and provides the performance I want/desire.
Your call .............
Old Apr 11, 2013 | 05:54 PM
La Changa-Reub
7th Gear
Ok that sounds good I will do that wasn't sure
If I needed that since summit guy said I needed
An hei. But thats what I thought so I wouldn't have
To buy a control box and bigger wires. My dad(his car)
Does want to eliminate points system though, so
What should I do
La Changa-Reub
7th Gear
Niceeeee ok didnt see that post I will do that then!
Old Apr 11, 2013 | 05:57 PM
La Changa-Reub
7th Gear
Thank you ,
How much is that unlite running or do u have a part number to check it out?
Old Apr 11, 2013 | 06:18 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
only thing about your original to look at would be the bushing wear and slop of the shaft in the housing.
Old Apr 11, 2013 | 07:30 PM
Mike Ward's Avatar
Mike Ward
An hei.
Naw- you're kidding? Look up the word 'upsell'
My dad(his car)
What should I do
Tell your dad to stop spending your inheritance.
Old Apr 11, 2013 | 07:43 PM
yyz1970's Avatar
yyz1970
nothing wrong with the OEM
Old Apr 11, 2013 | 11:29 PM
7T1vette's Avatar
7T1vette
If you don't want points, install a GM HEI distributor.
Old Apr 11, 2013 | 11:41 PM
glackore's Avatar
glackore
Thank you ,
I believe around $400.
Old Apr 12, 2013 | 06:05 PM
La Changa-Reub
7th Gear
@mike ward yea he really did got me because I'm
Pretty ignorant on that part so now learning more about
I'm like wow he really almost got me lol. Haha yea
He's killing me ima have nothing on will for me.
N as I checked nothing wrong with the distributor
Just should I Change the gear to bronze or leave iron one.
Old Apr 12, 2013 | 06:12 PM
Blame's Avatar
Blame
Just today i rebuilt my stock distributor for my 295 hp crate motor. A aftermarket is nice but upgrading coil, bosh platinum plugs, and 8mm wire makes my baby purr like a kitten. Plus it was cheaper to rebuild then buy a all new so call performance distributor.
Old Apr 12, 2013 | 06:33 PM
drwet's Avatar
drwet
Your factory distributor is as good as any. Just rebuild it to reduce the end play and make sure the tach drive gears are sound and well lubricated. Set up the advance curve and you're good to go. If you want to eliminate the points ( and you should) I would go with the Pertronix setup. I have had the Unilite and it gave me trouble. My Pertronix has been bullet proof and I have friends with the same experience. One guy has had the same unit for 25+ years and its still going strong.
To Distributor question
