Coil springs
Old Apr 11, 2013 | 05:15 PM
billkat's Avatar
billkat
Default Coil springs
Replacing A arm bushings , ball joints ect. The springs are the OEM. Should I keep them installed or get new ? I was looking at Moog.
Old Apr 11, 2013 | 07:37 PM
DUB's Avatar
DUB
I rarely re-install the old springs when I do suspension work or upgrades. I usually install VB&P's coil springs. Higher spring rate and have never had a complaint. It all depends on if you are trying to keep it original or not.
DUB
Old Apr 11, 2013 | 08:33 PM
qwank's Avatar
qwank
use the old ones
Old Apr 11, 2013 | 08:43 PM
DucatiDon's Avatar
DucatiDon
C2 of Year Finalist (performance mods) 2019
2018 C2 of Year Finalist
The new springs are shorter and easier to install. I like the lower stance of the 550s as well.
Old Apr 12, 2013 | 10:10 PM
gcusmano74's Avatar
gcusmano74
The front spring rate on a standard suspension C3 varies from maybe 260 lb/in to about 300 lb/in. Most of the aftermarket springs are MUCH stiffer- 460, 475 or 550 lb/in. This higher rate spring will change the ride and handling balance. It will also require a stiffer shock absorber to control it.
If that's what you want.
If the ride height on the OEM springs still looks good, just clean them up and reinstall them. The factory specifies that the ride height be measured at the lower control arm. The difference in height between the C/L of the front pivot bolt and the bottom surface of the spindle support must be measured, and compared to the specs.
Old Apr 16, 2013 | 01:12 PM
Ralphbf's Avatar
Ralphbf
I went with the Moog front springs.
Slightly lower and a better ride than the 40 year old stock ones.
Ralph
Old Apr 16, 2013 | 04:22 PM
jb78L-82's Avatar
jb78L-82
Couple of points, the factory springs are very soft: <300 according to the gm specs. Any steel spring will sag and loose elasticity over time and with miles. I replaced my factory gymkhana/ F41 springs with 550's with no noticeable harshness with the same Bilstein HD shocks. I have made numerous upgrades over the years to the front suspension including poly control arm bushings, spreader bar, 255/45/17 ZR tires etc the car steers, rides, and handles better by far than the stock springs and suspension. Change the springs!!
Old Apr 19, 2013 | 02:47 PM
donyue's Avatar
donyue
I am not trying to take over the post here, but I have a small question for jb78L-82. How does the final ride height of the 550 springs compare to the factory springs?
I'm about to install the VBP 550 springs in my 77 and am trying to see if I should cut out any coils prior to installing. My engine is not a factory L82 anymore so I don't know what the final ride height will be. I think the best option is to install without cutting and then adjust the height but cutting the coils afterwards if lowering is desired. Just would rather not have to remove the coils to cut them after the installation.
Old Apr 19, 2013 | 02:54 PM
Alan 71's Avatar
Alan 71
Hi b,
There are often posts about people having ride height problems with new springs.... not as many as rear ride height problems.... but still on occasion.
If the ride height of the original springs is good, and you're satisfied with their performance... maybe re-use them.
Regards,
Alan
Old Apr 19, 2013 | 03:03 PM
DucatiDon's Avatar
DucatiDon
DUB
Good plan. I think you will find they are just right without cutting a coil.
Old Apr 19, 2013 | 08:42 PM
Ralphbf's Avatar
Ralphbf
If you decide to cut a coil out, it will make the spring stiffer.
Ralph
Old Apr 20, 2013 | 01:08 AM
Ibanez540r's Avatar
Ibanez540r
Somewhat on topic... does anyone know a way to verify a spring by appearance?
I bought a rolling chassis with a lot of new parts, and not sure what springs are in there.
To Coil springs
