Oil leak
Old Jun 2, 2013 | 04:20 PM
redman76's Avatar
redman76
St. Jude Donor '09
My experience is that temp fixes never work. You are better off just doing correctly the first time. Clean the area really good and then put in some UV dye (can get at NAPA) in the oil and look for leak with black light. At least you will know exactly where the problem is instead of chasing the leak. The UV dye works VERY WELL spotting leaks.
Old Jun 2, 2013 | 05:08 PM
redwhitekat's Avatar
redwhitekat
I will try that
