Top end build l48
I don´t know where you got the idea I was looking for advice on this thread. I was telling the OP my experience with the L48.
I didn´t put the 383 together because it was cheaper and faster to have someone else do it.
If you want to build your L48 have fun. But for 1800 I got a bigger engine, better rods and better pistons and 4 bolt mains.. It also has all the machine work done and it was assembled. So lets see, a good set of rods are about $400, pistons about $350 another $400 for machine work. And about 8 hours to assemble. I think it was worth the 1800.
My first post about asking advice on the L48, I always ask to see what someone else has done, even if I already know how I will do something or how it´s done I always ask. Someone may have a better way or a better product.
As for the 383 being strong yes of course I agree.. But again if someones just looking to wake up a street driven 40 year old antique car all they need is heads and a cam to get superior performance over the L82. Its all about how far you want to go and what you want to do.... if I wanted something up around 500 HP I'd personally want it in a more capable modern chassis....hell I'd go buy a c5...which I still might do someday.
I decided against building my l48 because it has over 100,000 miles. I found a rebuilt flat top 355 4 bolt with 12,000 miles that had bearing damage from a broken ring on Craigslist for 300... yes it cost me a bit more for a new crank and bearings but I enjoyed tearing it down and learning. I had originally bought a set of dart iron eagle 64cc heads for the l48 for 300 bucks on Craigslist which I had a shop check out and confirm were ready to go but decided to replace the engine and rebuild the original later .
I never had an L48 before and asked questions about it. And as for the advice I received I was told that it wasn´t worth the effort.
Well anyway enjoy your build and your car and remember there is a time and place to go fast.
lol my friend has a camaro old style with lt1 and straight pipe. Its kinda loud and no one cares. I realize my true dual will be louder with no cat but if it's too much for a Saturday driver ill throw on come mufflers. I planned on dumping the exhaust at rear axle.
1) restrcited to there intake due to patent
2) only beat out the speedway heads barely
3) if i remeber they wouldnt bump up compression enough
4) speedway saves me money on the heads and not having to buy an intake right now
4) and i think worse exhaust ports
remember if you go with a big cam the car is gonna be a real dog to drive until you correct the gears and converter..
Its like putting huge mud tires on a pickup without changing the diff gears to correct for it.... Rednecks do it and wonder why the truck cant get out of its own way and the motor and tranny burn up...
(nothing against lifted trucks done right I have one myself)
they might even give too much compression depending on your cam ,quench and head gasket choice...
2) Actually, in the Car Craft article, the speedway heads did a teensy bit better than the Vortec heads.
3) The Vortec and speedway heads both are advertised as having a 64cc combustion chamber.
4) If you are planning on using a Performer 2101, I would not wait until later to do it. As I said before, you can find them for 50 bucks without looking too hard. Swapping an intake manifold is a fairly involved process, you have to drain the coolant, and remove the distributor. Heater hoses, fuel lines, vacuum lines, etc.
5) The Vortec heads are known for having a strong intake port and a relatively weak exhaust port, which gives a poor intake/exhaust ratio. After looking at the flow numbers, I think the Speedway heads actually have a better intake/exhaust ratio, not because of such a great exhaust port, but I think the intake port is a little on the weak side compared to the exhaust, if you see what I mean. However, the ratio is what it is, and the conventional wisdom is that heads with very good I/E ratios lend themselves toward use with a single pattern camshaft.
I am planning on using the Speedway heads on my car in the next year or so, in conjunction with a single pattern camshaft. I'll let everyone know how it works out. Car Craft seemed to think the heads were good enough quality to use in their test, and Speedway Motors has an excellent reputation, so this gives me some confidence in the product.
Scott
Scott
