New Corvette owner
I am sure you will get plenty of responses from other 1980 owners on what they think will be best for you and your situation. Since you have already taken the wheels off to get at the calipers, were the rotors still riveted onto the car? Or have they already been drilled out?
Good luck on your adventure, and share some pictures with us!
IMO, this means that you should remove and rebuild all 4 of the calipers. You can have them stainless-steel sleeved (if they are not already); or, if the car will be regularly used, just polish up the bores (if in good condition) and reseal the pistons. In addition, you should rebuild the master cylinder, which is really a rather simple task using a readily available rebuild kit for the seals/gaskets in the M/C. Be sure to 'bench bleed' the M/C before installing back into the car.
All 4 of the flex hoses that connect the metal lines with the calipers need to be replaced if you do not have evidence of that being done in the last 10 years. Old hoses can lead to serious brake failures and even fires, if they are not kept in good condition; and the damage is on the inside of the hose where you can't see it!
Flush out all the old brake fluid COMPLETELY with the same type of fluid it presently has {hopefully, that is DOT 3, but check to be sure}. Doing this insures that old fluid, which may have contaminants and absorbed water in it, is replaced with all new fluid.
Select good quality brake pads that perform as you need them to. If you use it as a sports car frequently, you likely want some semi-metallic pads for better stopping and temp dissipation abilities. If you have a "cruiser", you may want ceramic pads which will stop just fine but not generate a lot of black, nasty brake dust all over the wheels.
When all of that system is refreshed, bleed the brakes (closest wheel to farthest wheel...2 bleeders on rear brakes). Then drive the car for a few days and bleed them again to rid it of any trapped air that was dislodged during driving activities.
Good luck with your project. Again, you do NOT have to replace many parts in the C3 system to get it back in good shape. Only replace those that really need it.
thorough and complete
It's best to overhaul the brakes.
