What do my plugs say?
Old Aug 26, 2013 | 03:49 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Default What do my plugs say?
Removed my spark plugs this weekend.
Anyone handy at reading plugs?
Note: the boot on 5 and 6 were dry as a bone.
Old Aug 26, 2013 | 03:57 PM
zwede's Avatar
zwede
Look pretty good. You're burning a bit of oil, looks like it's coming in via the intake valve. Could be PCV, intake gasket or valve guides/seals or similar.
Old Aug 26, 2013 | 03:58 PM
zuendler's Avatar
zuendler
You have screwed them out after idling?
Nothing look unusual to me. All similar and no hinds for oil burning.
Old Aug 26, 2013 | 05:51 PM
oldschoolvette's Avatar
oldschoolvette
how much run time on these plugs?
Old Aug 26, 2013 | 06:06 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Came with the car when I bought it in 2009.
I've put maybe 5000km on them, no idea how much before that.
Old Aug 26, 2013 | 06:08 PM
Belgian1979vette's Avatar
Belgian1979vette
Too hot
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
How does one tell oil is being burnt from the plugs?
Old Aug 26, 2013 | 06:40 PM
zwede's Avatar
zwede
Your first pic, the plug with the arrow pointing to it. There's some ash deposits on the center electrode, but only on one part. If you screwed it into the engine you'd find it points to the intake valve.
Old Aug 26, 2013 | 06:42 PM
bondoboy's Avatar
bondoboy
You can see a build up on the insulator and ground electrode.
Old Aug 26, 2013 | 11:40 PM
7T1vette's Avatar
7T1vette
How many miles on those plugs? With the white ash on the electrodes, it looks like it's running a bit on the "lean" side.
Old Aug 27, 2013 | 06:44 AM
scrappy76's Avatar
scrappy76
Look pretty decent. I really do not see much oil burning in them at all. maybe a little on the lean side.
Old Aug 27, 2013 | 10:03 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Lean would surprise me, I'm using the Holley HP EFI, it should be tuning itself
R45S are the plugs, are they the right ones for this engine (1970 corvette engine, TPI manifold)
Old Aug 27, 2013 | 10:39 AM
zwede's Avatar
zwede
I don't see anything that would indicate it's lean. There is soot on the last thread of the shell. The center electrode should stay white/light grey. Many people still expect a tan color, but that was from lead. Some premium pump gas will make a reddish color though.
I'd replace with the same plug.
Old Aug 27, 2013 | 10:46 AM
Belgian1979vette
Go 1-2 ranges colder and see if the discoloration on the groundstrap moves towards the middle of the bend. To me it looks like the plugs are running hot. I don't see any signs of it being too lean.
The one with the indication 'bad' looks as if it has had pre-ignition signs.
Note : an FI system tunes based on the O2 sensor. There are other things that can disrupt the info coming from the O2 sensor like exhaust leaks, missing etc.
To What do my plugs say?
