Was helping a friend diagnose a problem.Suspected a wiped cam,sure enuff.Look what he found.He was using Mobil Delvac, oil recommended for diesel engines.This was a Comp Cam kit,he said he followed break in procedures.Cam had about 4800 miles when problem surfaced.No racing just street use.....Click on pic below for video [IMG][/IMG]
[IMG][/IMG]
Seems that Delvac oil is around 1100ppm Zinc.Good reason to just go with a roller setup and avoid this risk.Performance gains are worth it in my opinion. He's determined to just clean out the oil pan,install a new Voodoo cam and lifters and run it..Any suggestions on the best method to do this? What brand of cam was wiped Mako? Mahalo's
BBCs are hard on cams due to valve train geometry and stiff springs needed for the heavy valves. I went with a hydraulic roller so I don't have to worry and can run any oil I like. Worth the extra $$$ IMO.
If not tearing down, I would consider buying a couple gallons of marvel mystery oil or just some 0W-20, getting one of those drill-driven oil pump primers, and running oil through the system to try to get every last bit of shavings out...
Personally, if I had the time and a few 100 $$$'s, I would go ahead and tear it down, clean and reassemble. Good chance there are particles in the bearings that would trash the engine later. Metal shavings are merciless.
heres a question , what are you guys coating the cam and lifter faces with when you install a new cam? i saw some clown coating one with bearing grease. i stopped him and told him he was getting ready to make a big expensive mistake, guess what!
Delvac is likely around 1100 Phoshorous that said there are different types of ZDDP some need higher pressure and temperature to shear and bond some lower. Most oil additive packages that will garner a CI-4 or CJ-4 rating will have elevated levels of detergents and dispersants that will compete with the ZDDP for the same space. All are polar molecules. This is why diesel rated oils have and have always had elevated ZDDP it is in the oil but it can't protect as well so initial levels have to be higher. My cam was a crane cam with Rotella 15W-40 in 2006. My guess is your buddy will be in that engine again soon looking at the wear on the lobe and lifter shown. Mine wasn't that bad and it took out everything in the bottom end.
I am suspecting a similar issue with my BB - what were the symptoms?
First symptoms were sluggish and a slight miss.Then she started popping.Told my friend sounds like a bad cam,he thought bad plug.Pulled valve covers turned the motor several times then he notice valve wasn't opening.If the oil he was using had 1100ppm zinc shouldn't that be enough to protect the FT cam?
MOLY LUBE.
I use gm e.o.s. assembly lube. It seems to work pretty good. As stated earlier roller cams work better.
I've seen lobes get worn but I've never seen one get removed like this one. That's quite a bit of metal that got circulated through the motor. I wouldn't want to put it back together without a fresh set of bearings.
I've noticed that the wiped lobe is on cylinder #8.
My neighbor had the wiped lobe on cyl #8 as well.
Is this common? Are the lobes at the end of the cam more susceptible to failure?
His lifter and lobe looked the same. All he did is change the oil and replaced the cam and lifters and his engine has been running fine since It's a 396.
From: Las Vegas - Just stop perpetuating myths please.
Not much to lose at this point. Like if a bearing is bad and gonna wipe its gonna wipe. If bearing surface still functional it can still perform its function for a normal lifetime. If brg bad then the crank will need to be turned anyways regardless of waiting for it to knock. But that is a lot of metal to expect the filter to catch it all.
Ya know it is a chevy and will keep turning with a lot of crap in it.
As for break in i will only use high press cam break in grease - every one sells their own now. Try and use some weak used stock vlv springs just for cam break-in if u can handle the effort. I see now a lot of low ratio rockers are available for break in to reduce spring press which are alot less work/effort but more expensive than weak vlv springs.
But ya know a lot of times its the owner that really doesn't know how to adj hyd lifters but think he does. Alot of owners assume they are on the base circle when they really ain't or think they can find zero lash when they don't know that either. Not to be sarcastic here but to many owners are in denial on how to adj their own lifters.
Interesting thread...my BB engine is in the shop right now with a wiped out cam lob. It will be interesting to find out what lob or cylinder it is. The cam that was in there was some type of Comp Cam.
I'm going back with a roller setup. My engine has all original parts and would still be running if the PO has not swapped the cam out. My builder is recommending a Comp Cam for replacement, we'll see!
