luggage rack
Old Sep 16, 2013 | 06:45 PM
evotz's Avatar
evotz
2nd Gear
Default luggage rack
First time posting so forgive any screw ups. I have a 1970 c3 that I want to put a rack on. I have read several posts and read several articles on instillation but haven't seen any mention on the centering of the rack front and back. Do I center it over the gas cap? Thanks.
Old Sep 16, 2013 | 07:01 PM
U17's Avatar
U17
Well ... You have to keep in mind the cover has to be able to lift to get to the cap ... So plan accordingly...
Old Sep 16, 2013 | 07:48 PM
Mooser's Avatar
Mooser
Way closer to the rear of the car, he gas lid almost hits the front when open. I've got the AIM type install sheet around somewhere, I'll have a look
M
Old Sep 16, 2013 | 10:15 PM
lvmyvt76's Avatar
lvmyvt76
make sure you really want the luggage rack, those holes are really hard to get rid off. I like the racks, some people don't, and that is alright with me.
Old Sep 17, 2013 | 12:55 AM
evotz's Avatar
evotz
2nd Gear
Thanks for the input. Definitely want the rack so I can carry T-tops on it.
Old Sep 17, 2013 | 08:48 AM
4 speed's Avatar
4 speed
I want to stripe my car and remove the rack, anyone use a plug of some type for the holes.
Old Sep 17, 2013 | 09:19 AM
1977L48's Avatar
1977L48
also keep in mind that there was no one template that they used when putting racks on the cars, no 2 are installed in the exact same location
Old Sep 17, 2013 | 10:09 AM
oledave60's Avatar
oledave60
From what I have read, the racks were a dealer optioned and were installed where ever a customer wanted it.
I didn't want the forward holes over the interior storage area, so I centered it over the gas lid.
Old Sep 17, 2013 | 10:39 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
As someone mentiond, you'll need access to your gas cap. Measure twice, drill once!
Old Sep 17, 2013 | 10:55 AM
7T1vette's Avatar
7T1vette
The T-tops will only tie down to the luggage rack if you also have the T-top lock-down brackets/locks for them. And, those brackets only fit correctly on racks made like the originals. Really research this well, because you don't want to install a rack that won't do what you want.
Old Sep 17, 2013 | 12:23 PM
4 speed's Avatar
4 speed
that rack it a little different then mine, mine has little "****" on several of the bars. is mine an after market ??
Old Sep 17, 2013 | 12:38 PM
1977L48's Avatar
1977L48
I know on mine the "****" as you call them are for the brackets that I put my T-tops on and strap down, and mine is factory.
Old Sep 17, 2013 | 02:23 PM
stevelischynsky's Avatar
stevelischynsky
My factory rack does not have **** so the **** were added sometimes later than 73
Steve L
73 since new
Old Sep 17, 2013 | 02:47 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by evotz
...want the rack so I can carry T-tops on it...
You will need the 1977 V54 luggage rack with the pins for mounting the hardware for carrying the tops. The V54s were installed at the factory and shipped with the car.
The 1977 assembly instruction manual (AIM) shows how they were installed at St. Louis.
Dealer installed racks did not come with the top mounting hardware.
Old Sep 17, 2013 | 03:26 PM
1977L48's Avatar
1977L48
So i should get my luggage rack re chromed and not replaced
Old Sep 17, 2013 | 05:47 PM
7T1vette's Avatar
7T1vette
There are chrome-plated steel luggage racks and there are stainless steel luggage racks. Some vendors sell luggage racks AND some aftermarket hardware that allows you to mount the T-tops on the rack they sell.
Find out exactly what rack you now have and call several aftermarket places to find the adaptation hardware for your rack to mount the tops.
Old Sep 17, 2013 | 09:02 PM
U17's Avatar
U17
My rack is titless and the brackets have been holding the panels for years ,sometimes at fast speeds... No problem ... yet.... The end of the Hot Rod Power Tour.. in the rain ...
Old Sep 17, 2013 | 09:39 PM
U17's Avatar
U17
Before brackets... just bag .... worked fine but lacked the "cool" look ...
To luggage rack
