Steering column
Old Sep 25, 2013 | 03:19 PM
silica's Avatar
silica
Default Steering column
hi, does anyone know what size are the nuts that hold the steering column to the firewall... im missing both and dont know what size to order? should i go with stainless steel or not necesary?
thansk
Robert
Old Sep 25, 2013 | 11:52 PM
my 76 ray's Avatar
my 76 ray
In my '74 they are 5/16 course (standard) thread and take a 1/2 inch socket or wrench. I'm not sure of the grade but you can't go wrong with 8. Stainless is not necessary.
Old Sep 26, 2013 | 02:00 PM
archer417's Avatar
archer417
1/2" socket on my 77
Old Sep 26, 2013 | 05:57 PM
DUB's Avatar
DUB
Flange nuts are correct. Grade 5 acceptable. But do as you like. And for what it is worth...there is a steel plate that mounts from the firewall side. This plate has one 5/16 stud attached to it...and the other is a carriage bolt. This stud and carriage bolt is what comes through the firewall and allows you to secure your steering column at the firewall.
DUB
Old Sep 29, 2013 | 11:33 AM
silica's Avatar
silica
thanks, ill order some nuts.. i actually have the plate and studs just no nuts on them... im restoring the whole interior tried some nuts but none seemed to go in easily... probably a fine thread nut... so i thought best to ask as i cant go to the local hardware store and get it, they only have metric... will order from uk.
Thanks a lot.
Robert
To Steering column
