oil pressure
Old Oct 2, 2013 | 07:05 PM
swensonm's Avatar
swensonm
Default oil pressure
I have searched but have not found so here goes. 74 L82 never rebuilt
What should my pressure at idle? Seems high at 60. Was about 40 before last oil change. Going to check with a gage other than console
Mike
Old Oct 2, 2013 | 07:26 PM
donyue's Avatar
donyue
Mike
Hi Mike,
My oil pressure is high at engine startup - 80 psi, but after the engine warms up normal operating temperature the pressure drops down to about 45 psi according to the gauge.
As the oil thins during warm up the pressure will go down. I believe this is normal for my engine.
Old Oct 2, 2013 | 07:44 PM
7T1vette's Avatar
7T1vette
Thicker oil will raise the pressure level. What viscosity installed at last oil change?
Old Oct 2, 2013 | 09:43 PM
TedH's Avatar
TedH
Just swapped out a Mellings High Volume to install stock volume.
At start-up, cold: 60+psi at idle
Once warm, about 40psi at idle
Sounds about right.
Old Oct 3, 2013 | 10:48 AM
REELAV8R's Avatar
REELAV8R
Sounds about right.
60 psi cold at idle is ok. Once warm should be more like 40ish.
Old Oct 11, 2013 | 01:38 PM
swensonm's Avatar
swensonm
Default pressure
Gents thanks for the answers. I will put a gage on the car this weekend but my factory gage is reading around 80 psi cold and around 65 at idle but at 70MPH is is back to 80. running 10-30. Am I going to cause any damage?
Old Oct 11, 2013 | 02:35 PM
REELAV8R's Avatar
REELAV8R
Maybe. Cold starts may cause some bearing wear if oil is so thick for the clearances your running that your getting that kind of pressure. Damage probably be limited to excessive wear on the distributor gear since it's working hard to give you 80 psi.
I would be somewhat concerned about oil bypassing the filter at 80 while in cruise.
I run 0w-40 mobil 1 with a high flow filter. running a 0w-something will drop that pressure a bit. My logic on high flow filter is it's better to have more filter media and maybe courser media to prevent bypassing of the filter at higher pressures and flow rates.
Old Oct 12, 2013 | 10:10 AM
Indiancreek's Avatar
Indiancreek
If you are at 40psi at idle, your lower end is in good shape.
To oil pressure
