flywheel bolt torque
Old Oct 25, 2013 | 09:02 PM
Dave Witman's Avatar
Dave Witman
Default flywheel bolt torque
ARP bolt torque instructions say 85 ft lbs for bb flywheel with there lube specs. 85 seems high to me. dave
Old Oct 25, 2013 | 10:26 PM
gve's Avatar
gve
60# is what the torque should be
Old Oct 25, 2013 | 10:44 PM
garygnu's Avatar
garygnu
that low .wow I thought it would be 100+ lb.
Old Oct 26, 2013 | 01:19 AM
7T1vette's Avatar
7T1vette
If they are ARP bolts, go with their spec. Bolt torque settings attempt to get the fastener into the 'elastic' zone. ARP would know best what torque their product should get.
Old Oct 26, 2013 | 01:52 AM
Solid LT1's Avatar
Solid LT1
ARP 200-2802 flywheel bolt kit, follow the instructions, Locktite #242 on threads, ARP Ultra lube under head, 85FT/LBS of torque. If you don't follow the ARP instructions, you risk fastener failure. We have found the ARP Ultra Lube to be very consistant and repeatable in measuring connecting rod bolt stretch, it is much better than the previous products.
Make sure your bolts are 200 SERIES bolts there is also a 100 series flywheel bolt, torquing specs are different I'll bet. Why take some ill informed "expert" suggestion from this forum when ARP has an easy instruction lookup on their Web site?
100-2801 kit, 75 ft/lbs.
Old Oct 26, 2013 | 08:28 AM
Dave Witman
Thankyou I ordered the correct lube.
To flywheel bolt torque
