Help Engine Guys
Old Nov 6, 2013 | 09:34 PM
pacecar620's Avatar
pacecar620
I have no experience with the Comp Cams rockers, but plenty with stockers. Did you molycote the rockers and rocker ***** when assembling? Once they start to gall, it's all over, there's no saving them. Have you contacted Comp Cams customer support about your problem? Also, their rockers come in sets for "perimeter bolt" heads and"center bolt" heads (meaning the rocker covers) with the center bolt style having offsets on some of the arms and no offset for others. You have to make sure that you install the offset rockers on the proper locations or incur excessive side loads or complete binding on the rockers. I note that not all of the rockers are blued, so my long distance diagnosis (guess) is that some of the rockers were installed in the wrong locations. I'd contact Comp Cams so not to have a repeat performance.
Old Nov 6, 2013 | 10:54 PM
malicatasr's Avatar
malicatasr
pacecar620 - I have had no prior experience with these rockers either. But the engine builder specified these when we put this combo together. The pictures may be deceiving. The heads are late model 96 to 2002 vortec heads sitting on an 89 roller block. I essentially have center bolt heads but I have an adapter on there to put older style valve covers on. According to CompCams these are the right rockers for this setup. Personally I think I over tightened these valves when I setup the engine and possibly fatigued the pushrods.
I'm still hopeful that the piston is okay. The spring is broken but it's still kind of working, maybe because its a double. Don't really know. I used JE/SRP flat tops -5cc and they were expensive If the piston got wacked I may just pull the motor again. I also have not found any metal in the oil or filter which I cut open. I going to keep my fingers crossed till I can get that head off.
Old Nov 8, 2013 | 03:57 AM
billla's Avatar
billla
St. Jude Donor '14
The broken spring is also a "good" indication; typically (not always) this indicates the spring "went solid" or lost clearance between the coils - another indication of bad adjustment...but I would also check all your valvetrain clearances very carefully...
Old Nov 8, 2013 | 12:32 PM
BKbroiler's Avatar
BKbroiler
As for those Comp rockers - I had a set of 1.6s on my Vortec heads, with enlarged pushrod holes with a flat tappet cam and now I have 1.5s with a roller cam. No problems with either set.
Old Nov 8, 2013 | 02:16 PM
TedH's Avatar
TedH
Originally Posted by hugie82
Broken spring, pushrods jumps out of lifter, rides outer edge holding valve open, BANG!, piston smacks valve.....
Hopefully damper spring prevented valve-to-piston impact.
Old Nov 9, 2013 | 05:01 PM
malicatasr's Avatar
malicatasr
The damper spring did exactly that. The piston was fine and a valve stem seal on the cyl hot wiped out. So a quick trip to my machine shop and I now have all the pieces to reassemble
Old Nov 11, 2013 | 08:56 PM
malicatasr's Avatar
malicatasr
Quick update. I got it all back together today and it fired up first crank. I primed the oil system and took a quick stab at the timing and first crank 70 psi oil pressure and sounds great. I just have to put the valve covers on and so some house keeping and hopefully all is well
Old Nov 11, 2013 | 10:14 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
I like happy endings! I just had a happy "New 383 engine issue" ending as well a few weeks back!
