71' engine ID
Old Nov 9, 2013 | 11:27 PM
Land Shark's Avatar
Land Shark
Default 71' engine ID
Hello all, I picked up what's suppose to be a numbers matching 71' LT1. Well, its not! Casting numbers on driver side of block is 14010207, I can find information on this but not on the deck plate, front passanger side of block :
1004TDR
CAZ106892
I've exhausted all avenues trying to find info on the above numbers. Any help would be greatly apperceiated!
Also what is a 71 coupe in good condition, but not numbers matching worth?
Old Nov 10, 2013 | 09:24 AM
Alan 71's Avatar
Alan 71
Hi ls,
I believe that block casting number, 14010207, indicates a 350 engine from the 80-85 era and was used in both cars and trucks.
The value of the car you're bought is pretty difficult to even guess at with out considerably more information.
Regards,
Alan
Old Nov 10, 2013 | 10:16 AM
7T1vette's Avatar
7T1vette
How did you define "numbers matching" when you were negotiating a price on the car? If you didn't specify what that term meant...and the stamping on the block, the VIN on the windshield post, the VIN derivitive on the transmission, and the VIN on the frame all match...it's a "numbers matching" car.
The only folks who even consider that the casting numbers and dates must match are the super-serious folks that dabble in very original, high dollar cars.
If you spent extra money for a "true" numbers matching car and didn't check it out well enough to know you didn't get one....too bad. That's your responsibility. If you just bought a nicely done, reasonably restored car with matching primary numbers, you got what you paid for.
Old Nov 10, 2013 | 12:07 PM
Revi's Avatar
Revi
14010207 1980-85 350 190hp & up 2/4bbl corvette
Old Nov 10, 2013 | 01:01 PM
Land Shark's Avatar
Land Shark
I'm not a serious collector just like C3's. I had my 73 in the shop and while checking on it this weekend he asked if I would be iterested in trading car+ $$ for a 71 numbers matching.
I've figured out its not #s matching and now we are working on a new price. Other than the non matching motor, and a small wiring issue with the tail lights and turn signles the car is in good condition.
Im just looking for some advice from experienced corvette owners.
Old Nov 10, 2013 | 01:35 PM
Mike Ward's Avatar
Mike Ward
Dupe
http://forums.corvetteforum.com/c3-g...is-engine.html
Double dupe
http://forums.corvetteforum.com/c3-t...uffix-caz.html
Old Nov 10, 2013 | 01:59 PM
Alan 71's Avatar
Alan 71
Hi LS,
The value of the car will depend greatly on whether it actually an LT-! car.
There is fairly long list of things to check in the engine compartment, interior, and chassis.
A car that left St.Louis as an LT-! still has some additional value above a base engine car even if it's original engine is gone.
After you determine if it's an LT-! car the completeness, originality, and condition it is now will determine is value.
Regards,
Alan
Hi, just read your other threads.... too many to follow and make sense in replies.
IF it's an automatic and it was originally it's not an LT-!.
If you were told it's an LT-! you should be careful about ANYTHING you've been told about the car.
Old Nov 10, 2013 | 02:30 PM
Land Shark's Avatar
Land Shark
Originally Posted by Alan 71
Hi LS,
Regards,
Alan
Thanks Alan 71, I'm sure it's probably not an LT1 but, what would I look for other than engine castings?
From the vin 194371S101300 I find that it is a 71 out of St.Louis.
Old Nov 11, 2013 | 11:06 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Land Shark
...From the vin 194371S101300 I find that it is a 71 out of St.Louis...
All C3s were assembled at St. Louis through the 1980 model year. Most 81s were assembled at St. Louis, but the Bowling Green facility opened in June of 1981. Beginning with the 1982 model year, all Corvettes have been built at Bowling Green.
To 71' engine ID
