LS header selection #%+%#
Old Nov 22, 2013 | 10:30 PM
  #41
AR Headers's Avatar
AR Headers
Premium Supporting Vendor
Originally Posted by mffi115
Nick,
Will the stock clutch Z-bar clear these headers and will they have O2 sensor bungs? If so, put me down for a set. I'm across the Sound in Fairfield, CT. I, too, have the Melrose and am sick of them.
Thanks,
Carl
Carl I believe it will but how do you get the stock Z-Bar to work with the LS engine? Is there a kit that mounts the ball on the block? Do you drill the block? Let me know. Thanks.
Nick
A.R. Headers
Old Nov 22, 2013 | 11:27 PM
  #42
RickyBerg's Avatar
RickyBerg
I don't know the answer to your question but maybe this kit could be a good ground for modifications?
I have now run it on my 454 GenV for 3 years.
https://sdparts.com/details/scoggin-...s-center/sdcbv
Old Nov 23, 2013 | 01:26 AM
  #43
ignatz's Avatar
ignatz
Default z-bar location
yes there are kits, here's one for an LS motor
but regardless of whose kit it is, all that really matters is that the z-bar location is given by a perpendicular from the position of the mounting bracket on the frame rail to the block or alternatively the approximate length of the pushrod to the yoke in the bellhousing. The number 7 exhaust tube should not be anywhere in the vicinity. If it goes forward of the iron manifold it will be OK. Maybe this will help?
Old Nov 23, 2013 | 06:08 PM
  #44
NemeSS's Avatar
NemeSS
fwiw I am using 98-02 fbody headers in the 69 swap im working on.
using side pipes exit though and a 4l80e trans. but I would b able to make a full length exhaust but would prolly hang lower if using 3in tubing all the way to the back. but on this build not using the trans crossmember holes for exhaust.
Old Nov 23, 2013 | 07:06 PM
  #45
THE BLACKBIRD's Avatar
THE BLACKBIRD
98-02 fbody headers work just fine with are motor mounts
69 vette with 6.0 and 4l80
bad picture but you can see the header there, just need to cut down the collector some.
Old Nov 23, 2013 | 07:20 PM
  #46
Gordonm's Avatar
Gordonm
I have a set of the F body headers and was not pleased with the fit or the angle they came out of. They cold have worked but I was just not happy with the over all fit. My coils are on the firewall and they were to close to the firewall.
Old Nov 26, 2013 | 06:46 PM
  #47
mffi115's Avatar
mffi115
Default Brackets and kits
Nick
A.R. Headers
Nick,
I used the motor mounts from VettAid.com and the optional Z-bar bracket. It's similar, if not the same ones, as the pic in ignatz' post above.
I also have the bracket that RickyBerg posted above. It came with the C3 TKO500 kit I got from www.hurst-drivelines.com/?page_id=120. but I didn't use it.
No drilling, just brackets. Are you ready for me to call and talk about your headers for a possible order? How far are you from the Bridgeport Ferry at Port Jeff...just wondering if I would save on shipping to pick them up?
Carl
Old Dec 2, 2013 | 09:02 PM
  #48
Nasti12's Avatar
Nasti12
I just pulled my headers out of the box, to check the fit. I was very disappointed when I looked under the car. I see I'm not alone in this.
Old Dec 2, 2013 | 10:01 PM
  #49
diehrd's Avatar
diehrd
Any pics of what the fit issues are ? I am mainly subscribing to show this topic to a local race car fab shop , see if he cares to make these headers.
Old Dec 2, 2013 | 10:29 PM
  #50
Solid LT1's Avatar
Solid LT1
I take it that your talking about the Melrose headers.......Send them back! Buy a set of AR Headers, they are stainless and well made! Looking forward to seeing the C3 LS header photos.
Old Dec 3, 2013 | 12:56 AM
  #51
Nasti12's Avatar
Nasti12
Diehard - I posted some pics of the problem in my album.
Solid LT1 - the box and bubble wrap went out in the trash Sat. Morning.
Old Dec 3, 2013 | 08:20 AM
  #52
diehrd's Avatar
diehrd
Wow looks like low hangers... Laugh that was funny ... Seriously they have it to low .. and personally the O2 bung should be on the out side .. Thanks for the pics ill forward it to my fab buddy .
Old Dec 3, 2013 | 10:57 AM
  #53
Gordonm's Avatar
Gordonm
The Melrose headers are terrible. I can't believe they are even sold. I cut mine up because they had to be modified to fit the steeroids then the low hanging issue is terrible. I have an appt with AR tomorrow and am going to pick them up and put them on. If I have time tomorrow afternoon I will put them on and post some pictures. I am very confident these are going to work well and fit perfectly.
Old Dec 3, 2013 | 11:34 PM
  #54
Tim 1973's Avatar
Tim 1973
Solid LT1 - the box nd bubble wrap went out in the trash Sat. Morning.
wow, way too low, I modified some hookers and fit great with sternoids ... these guys that are fabricating them need to to get a rolling frame with LS engine installed so they can get it right.
Old Dec 3, 2013 | 11:53 PM
  #55
diehrd's Avatar
diehrd
I got them ,, I am waiting on him to reply .. Those who made yours are close but should refund you or make them right .. What have they said ?
Old Dec 4, 2013 | 03:27 AM
  #56
Nasti12's Avatar
Nasti12
Diehard - I spoke to the owner this morning. He had heard about the fit already. Apparently, these headers were designed with the G70-15 in mind, vehicle sitting at factory height. He said he would take them back, if they were in good shape. He recommended putting the car on the ground and looking at the actual clearance instead of going by the oil pan. I'll do that after I get the driveshaft bolted in but I would like a better fit then what I have now.
Old Dec 4, 2013 | 06:10 AM
  #57
Gordonm's Avatar
Gordonm
BS. The tires have nothing to do with it. There is very little clearance even with tall tires. I got. The runaround when I told him about mine. " All cars are slightly different" is the story I got. I'm. Not buying that. I have some pictures of how low they hang. Not even close to fitting correctly.
To LS header selection #%+%#
Old Dec 6, 2013 | 08:20 AM
  #58
diehrd's Avatar
diehrd
I am calling the local fab guy he , replied to me on face book where I had sent him a link to this topic. I will post what he says after I talk with him.
Old Dec 6, 2013 | 11:05 AM
  #59
Solid LT1's Avatar
Solid LT1
G70-15? What century is this guy living in? Dosent he know all us LS types go with at least radial tires? WTF?
Old Dec 8, 2013 | 11:06 PM
  #60
Nasti12's Avatar
Nasti12
Any photos or updates on the new headers?
