Dyno Tested Crate Engines - Question
Specifically the flat tappet cam.....
Looking at this...
http://www.jegs.com/i/Blueprint+Engi...FaZ7Qgodfi4AYA
Lars
I asked why and they said because it's been sitting around for months...
Does that make sence?
Not to me.....
You are correct every single engine is ran on the dyno before we package or send that engine out, the reason why we still do recommend that you follow a break-in once you get the engine is because we cannot guarantee how long that engine has been sitting in storage before you receive the engine. This is also a good time to double check your initial and total timing on the engine and to make sure that you do not have any leaks on the engine anywhere. I hope this makes sense as to why we say that and if you have any other questions let me know.
Thank You,
Andrew Obermeier
BluePrint Engines
Product Specialist
1.800.483.4263 ext # 138
andrew@blueprintengines.com
Thank You,
Andrew Obermeier
BluePrint Engines
Product Specialist
I'll probably be ordering next week
Chevy heavy beam rods with 150,000 PSI bolts
Hypereutectic pistons; 10.0 to 1 Compression
Hastings Moly rings
Hydraulic flat tappet cam
Melling high volume oil pump
Heavy duty double roller timing set
GMPP
It is a forged crank , and a roller cam .. and 9.6 to 1 with a tad more power ..
Makes no sense to me...
Possibly they're just firing the engines briefly vs. doing a full dyno run with the associated sheet. IMHO, that would be a Bad Thing.
I upgraded to the forged crank, Quik Fuel 850 carb, 8.8 mm accell wires, new flywheel balanced to this engine, MSD box, paid an extra $350 for 8 pulls on the dyno to fine tune MY engine. All told,, $6529.00 shipped to my door. Think it's a good deal, can't wait to get it. The '79 has been off the road for 10 years. Good luck with yours, hope it treats ya well.
Bill A
I contacted our engineering team for some clarification - ALL cams, flat tappet or roller cams are broken in when we start them before we do our dyno runs. But when I checked with our quality control department they recommend that the customer still does the break in as well - just as a precaution and to make sure there are not any issues with the engine during that first startup for you. It does seem redundant but it is better safe than sorry.
EVERY engine is dyno tested before it goes into inventory. And because we supply all of the major mail order catalogs (Summit, JEGS, and Speedway – along with many other great customers!) we do our best to keep them on hand and ready to ship when an order is placed. In addition, every engine DOES come with a Dyno sheet – specific to your engine (including date/time, and many other details that our competitors would love to get their hands on!)
In reference to the question about a 383 with a roller cam and forged components – we build that too! Here is a link to our website and that specific engine. http://www.blueprintengines.com/inde...ase-bp38316ct1.
Let me know if you guys have any additional questions!
Thank You,
Andrew Obermeier
BluePrint Engines
Product Specialist
Thank You,
Andrew Obermeier
BluePrint Engines
Product Specialist
Thank You,
Andrew Obermeier
BluePrint Engines
Product Specialist
Scott
