1971 coil question
Old Jan 26, 2014 | 01:32 PM
TWaldo's Avatar
TWaldo
Default 1971 coil question
Have a box of parts from PO...located this coil...is it factory original?
Old Jan 26, 2014 | 02:48 PM
Revi's Avatar
Revi
Not original, it's a replacement.
An original 71 coil would vary based on engine installed. The numbers are embossed (or raised) in the coil, not printed.
270 B-R, Base motor
272 12-V TI, LT-1
287 B-R, LS-5
263 TI, LS-6
Old Jan 26, 2014 | 03:00 PM
Alan 71's Avatar
Alan 71
Hi,
I believe the 3 embossed digits are the last 3 numbers of the coil's Chevrolet part number.
Regards,
Alan
Old Jan 26, 2014 | 07:10 PM
LT-1 kid's Avatar
LT-1 kid
the bracket looks original though
Old Jan 27, 2014 | 10:10 AM
TWaldo's Avatar
TWaldo
270 B-R, Base motor
272 12-V TI, LT-1
287 B-R, LS-5
263 TI, LS-6
Is there a way to "test" the coil and condenser? Matching these up to a newly Lars rebuilt distributor and Qjet...removing HEI. Thanks for replies everyone...
Old Jan 27, 2014 | 11:37 AM
7T1vette's Avatar
7T1vette
That condenser is "toast". There is no way an 'original' condenser is still good. BUT, it is only there to eliminate noise from your car's radio output. If that's not an issue, your best choice would be to pull the lead completely out of the condenser, trim back the end that you pulled out so there is no wire protruding, clean up the coil, condenser body and bracket, glue the [trimmed] lead back into the body of the condenser, then stick it all back on the car. You will have the original bracket and original (noise suppression) condenser lookin' good.
If the coil is still good and it has the correct coil resistances for your ignition, just repaint it semi-gloss black and stick it in there, too.
Old Jan 27, 2014 | 01:30 PM
TWaldo's Avatar
TWaldo
Cleaned as suggested. Still suggest flat black? Should I look for replacement condenser? NAPA? Radio works with no interference...not factory per PO.
Old Jan 27, 2014 | 01:46 PM
Alan 71's Avatar
Alan 71
Hi tw,
I think the original coils were quite shiny.
Certainly not flat and maybe a bit more gloss than semi-gloss.
Regards,
Alan
Don't lose the screws for the condenser and bracket (didn't see them in the latest picture)... they're nice to have. Unusual head on the condenser screw, and self tapping tip cut into the bracket screw.
Old Jan 27, 2014 | 02:18 PM
TWaldo's Avatar
TWaldo
Originally Posted by Alan 71
Hi tw,
Regards,
Alan
Thanks Alan...just reinstalled screws. Great to have knowledgeable and helpful responses.
Old Apr 7, 2024 | 08:29 PM
jbakyy's Avatar
jbakyy
Hello Alan, what brand and type of coil do you recommend for 1971? Thank you
Old Apr 8, 2024 | 12:28 AM
speedreed8's Avatar
speedreed8
That was 10 yrs ago.
To 1971 coil question
