How much grease?
Old Feb 25, 2014 | 06:14 AM
LudemJo's Avatar
LudemJo
Default How much grease?
OK, back in my heavy equipment days we would grease fittings until the grease visibly came out of the connection or boot, whichever was the case.
As I am rebuilding my front suspension and installing all these grease fittings, I am wondering how much grease should be pumped in. I don't want to over do it after all the work I have put in over the winter.
Thanks for any advice!
John
Old Feb 25, 2014 | 06:40 AM
Mooser's Avatar
Mooser
For the initial go, add grease until you see it start to come out . Wipe off the excess and go.
For re-grease, most just go until the boot swells or a bit leaks out the top. Really, it's meant to flush out old grease and any contaminants so you should let the grease come out the end until "fresh" grease shows.
And yes, lots of rags
M
Old Feb 25, 2014 | 06:42 AM
Mooser's Avatar
Mooser
Here's a pdf from moog on their recommendations
http://www.moogproblemsolver.com/_pd...K10_103_En.pdf
M
Old Feb 25, 2014 | 07:57 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
M
Interesting read! I think like most people, I've always kept pumping until clean grease comes out.
Old Feb 25, 2014 | 08:02 AM
LudemJo's Avatar
LudemJo
Great info! Thanks.
John
Old Feb 25, 2014 | 11:49 AM
7T1vette's Avatar
7T1vette
Ball joint grease boots are sometimes the exception to this. Sometimes, those items are sealed from the outside and have no place for 'excess grease' to be expelled. If you keep pumping, you just rupture the seal.
In such cases, just pump the grease in until it appears that there is adequate excess within the boot-seal. DO NOT overfill. Overfilling is not a problem with flat, open-edged dust boots like on steering knuckles. Know what you are greasing and fill that joint accordingly.
Old Feb 25, 2014 | 11:54 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
...........after learning the hard way!
(On heavy equipment the rule was "Grease cost much less than a rebuild")
To How much grease?
