HI guys..
I bought another '75 convertible a few months ago and when driving it home I had to stand on the brake pedal to bring it to a stop. I guess that would indicate the booster is not working. I have the body off it and the motor out and want to refinish the engine compartment. Before I bother to make the booster "pretty", is there a way to test it under the current conditions ? If it is in fact "bad", can it be rebuilt ? Or...should I just go to Oreilly's and buy a new or rebuilt one ? I have already just about blown my budget so cost will be a factor.
TIA
Ya'll Enjoy !
Larry
The factory boosters have a typical ~4" of brake pedal travel to get any secure braking, it is typical of all GM cars over the decades.....and especially noticeable on the C3 vettes.....nature of the beast...there are guys who are used to it, and guys like me that hated that feeling,.....
the ONLY way to ditch it good and proper is to put in a Hydro Boost brake setup that runs off the power steering pump, THEN the pedal has about 2" of travel and the brakes are hard as a brick.....also ditch that silly f/r brass block with the switch on it, plumb directly to the m/cyl......
and obviously the calipers need be checked out, and probably O ring pistons installed....
further questions, feel free to PM me....as I maybe not see this thread.....
I don't entirely agree with just getting another generic booster. I had a rebuilt one installed recently that had an internal flaw. As soon as you would start the car the booster would start to gradually pull the pedal down and apply the brakes. You could pull it back up but as long as the car was running the pedal would creep down. Do yourself a favor and buy the best quality available.
I recently installed a replacement booster on my '79 mainly because I didn't like the look of the original. The replacement works, but there is something about the feel of it I don't like. Its not the same as the original. The pedal just feels a little more mushy. The brakes work, but its not right. I had the stock booster on my '66 rebuilt and replated a few years ago and its perfect. I'm thinking about having the stocker from my '79 rebuilt also. Just sharing my experience. Take it for what its worth.
Are you absolutely sure that the booster was getting good vacuum signal and that the check-valve at the booster input was functioning properly? It would be disappointing to buy a new or rebuilt booster, only to find out that vacuum wasn't getting to it.....
Good idea.....I will check the vacuum plumbing first. I think the responses I'm getting will have me keeping what I've got and making it work. It is rusty and ugly tho. Thanks everybody !!!
Ya'll Enjoy !
Ya'll Enjoy !
Larry
A little wire brushing, masking and painting will pretty it up real well
And as mentioned before, original boosters seldom go bad.
If your oil dipstick is on the left side...the booster is different than that of the engine with the dipstick on the right side. They both will bolt to the firewall...but the shape of the outer half of the booster is different...along with how the outer half is stamped for the master cylinder is also different.... and if you use a later year model...you will have a fit in getting to and correctly using your oil dipstick.
I have run into the vacuum check valve not working correctly and causing a booster to seem to be bad.
Also I go to a "Piretek" shop near my shop and get the thick walled hose like GM used on many year models. I prefer it instead of regular 3/8" fuel hose....due to the correct tension clamps work on the thicker walled hose versus the fuel hose.
Hi Guys...
Don't want you to think I'm ignoring your help and suggestions but I've got family coming down from the frozen north tomorrow. When I'm free again, I'll let you know whats goin' on with my problem. About a week maybe ...? You guys are great.
Ya'll Enjoy !
Larry
Would a rubber brake hose that's collapsing on the inside cause his problem ?
YES. Not able to pull the amount of vacuum required...which would be the same as if you used a small vacuum line instead of a large diameter hose. Less volume...and would take time to get the booster to proper vacuum.
I have seen the hose suck shut due to it being the wrong type of hose.
