Mangled Oil Filter
Old Mar 13, 2014 | 01:25 AM
bluedawg's Avatar
bluedawg
Originally Posted by 7t9l82
460 channel locks.
X's 2. Usually works. if not, rip the filter apart, once you have tention from the rubber seal seperated from the threaded section of the filter, channel locks again.
Old Mar 13, 2014 | 08:59 AM
confab's Avatar
confab
Originally Posted by Sayfoo
You may have to end up tearing the case and inards off and then using a chisle or old screwdriver to tap the end around and off.
This ^^^
Old Mar 13, 2014 | 09:17 AM
Brcmpbl's Avatar
Brcmpbl
Getting flashbacks, ha. Only happened once to me but it was just the worst. Added a solid hour or more to a job I wanted to do to relax one night.
In the end I used one of those strap oil filter wrenches and just worked at for a long time and it eventually loosened a little, then a little more...
Old Mar 13, 2014 | 09:21 AM
lvmyvt76's Avatar
lvmyvt76
looking at the holes put in the filter by the screwdriver, he has tried to turn the filter the wrong way.
I have changed many a filter, if the filter strap did not work, the screwdriver thru the filter did work, now I was turning it the correct way.
I wonder what the drain plug looks like?
Old Mar 13, 2014 | 09:29 AM
Ken_4fun's Avatar
Ken_4fun
I have had to use the screwdriver trick a couple times.
My only suggestion, it to try to slightly tighten, then loosen.
Once you break the "seal" of the rubber seal the filter will come off.
I can tell you WHY it happened. It wasnt overtightened, IMO, when the filter was installed, they didnt take their finger, dip it in oil and put a small bead of oil around the rubber seal. I always do that and never have a problem.
The ones I have used the screwdriver trick on, the rubber was dry as a bone.
Best luck,
ken
Old Mar 13, 2014 | 10:49 AM
wisoutlaw's Avatar
wisoutlaw
Originally Posted by 82CFI
This is what I would have asked if I was the 1st poster to reply after the OP's thread opening post: "Are you certain during your 1st attempt that you were turning the filter the correct direction?" It is not so apparent when something is screwed in upside down and you're not under it looking up but on the side of it exerting twisting pressure on the filter wrench. Many stuck oil filters are the result of not taking a few seconds to get oriented before starting to turn it ... just 3/4 of turn more on a filter will freeze it to the block and require some innovative techniques (like some mentioned above) to get it off. Good luck.
Here's a trick my grandfather taught me when you're upside down and reaching behind your head and get discombobulated about which way to turn the wrench. Curl your fingers and extend your thumb, like giving a thumbs up. Point your thumb in the direction the piece needs to move (in this case point away from the block). The curl of your fingers is the direction you turn the wrench. Use your left hand if you're working with left handed threads. Works every time.
Old Mar 13, 2014 | 10:58 AM
CanadaGrant's Avatar
CanadaGrant
Ahh, I'm left handed... What do I do?
Old Mar 13, 2014 | 11:11 AM
wisoutlaw's Avatar
wisoutlaw
Point your thumb in the opposite direction you want the piece to move. Or find a helper and use their thumb.
Old Mar 13, 2014 | 12:50 PM
akdale's Avatar
akdale
Another vote for a pipe wrench, it worked for me the one time I had this happen. From then on I never let anyone change my oil for me. That was almost 35 years ago, guess I am still processing trust issues.
Old Mar 13, 2014 | 07:31 PM
7T1vette's Avatar
7T1vette
It appears to me that the OP is trying to turn it in the proper direction. I'm betting that it was put on "dry" and the heat sealed the gasket to the engine surface. The most sturdy part of that filter is just below where it mates with the engine. The farther down on the filter you place a wrench, etc., the more flex the filter housing has.
Old Mar 13, 2014 | 09:45 PM
scottyp99's Avatar
scottyp99
If you did this to a sbc oil filter, you would be turning it clockwise, as viewed from the bottom, which would be tightening it.
Scott
Old Mar 13, 2014 | 09:47 PM
rep69's Avatar
rep69
a chain wrench may help
Old Mar 13, 2014 | 09:51 PM
  #33
Jeff_Keryk's Avatar
Jeff_Keryk
Yeah, sometimes you get a doozey. I recently serviced a new Accord; the dang filter was either over tightened or no oil or both from the factory. It's always good when they move...
I don't go anywhere without my trusty (large) channel lock pliers.
Old Mar 13, 2014 | 10:09 PM
  #34
bhk2's Avatar
bhk2
If you have superman hand strength, I have had luck with 80-100 grit sandpaper--the non-slip surface sometimes works like magic.
Old Mar 13, 2014 | 10:35 PM
  #35
Majoho's Avatar
Majoho
Or you could just remember, "leftie loosie, righty tighty".
