AC
Old Jul 19, 2002 | 11:37 PM
Ross78's Avatar
Ross78
Default AC
I need a new AC hose. I am considering using R134 instead of R12. I have heard conflicting reports on R134.
I would like to hear from Vette owners that have converted
Old Jul 19, 2002 | 11:59 PM
zwede's Avatar
zwede
Default Re: AC (Ross78)
Don't believe the nay-sayers. R134a works just fine. I have 2 converted cars (vette & caddy) and both are cool.
Old Jul 20, 2002 | 06:35 AM
Larry B.'s Avatar
Larry B.
Default Re: AC (zwede)
Mine works great.. Stock 69 system. I did replace the drier with a new one compatible with R!34a. You need to use ESTER oil (not PAG). You have to be carful not to overcharge the system. Overcharging is very common and the main reason people are not happy with R134a. R134a does tend to leak a littl easier. I've done several cars with no problems.
Old Jul 20, 2002 | 09:30 AM
Scott78's Avatar
Scott78
Default Re: AC (silvervetteman)
R134a works fine, the trick is to find the "sweet" spot of the charge. To much or to little and you won't see the coolest vent temp. Good Luck
Scott
To AC
