1972 paint prep
Old May 7, 2014 | 11:53 PM
ray3222's Avatar
ray3222
Default 1972 paint prep
After removing paint with a razor blade, a dark gray material remains. Is this the primer or fiberglass?
Also, what is the best filler for blemishes in the fiberglass?
Thanks.
Old May 8, 2014 | 09:27 AM
Alan 71's Avatar
Alan 71
Hi Ray,
One of the original primers was dark gray. It's very difficult to remove.
Many people use sand paper to remove it.
It depends on what the 'blemishes' are as to what is best to use on them.
Are they small 'divots', cracks, exposed glass fibers?
Regards,
Alan
Original gray primer.
Old May 8, 2014 | 10:45 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by ray3222
...Is this the primer or fiberglass?...
Post a pic. Does your gray come off with the razor blade?
...what is the best filler for blemishes in the fiberglass?...
You can use almost anything to fill nicks.
Old May 8, 2014 | 07:19 PM
DUB's Avatar
DUB
I agree...a photo of your surface is needed.
As for a filler to fill in blemishes...it all depends on the severity of the blemish. But if it were me...I would use nothing but Vette Panel Adhesive/Filler from Evercoat.
But...the dark grey primer/sealer...if that is what it is will need to be thoroughly removed BEFORE you apply the VPA.
DUB
To 1972 paint prep
