Interior trim gap '72
Old May 14, 2014 | 07:01 PM
kansas123's Avatar
kansas123
Default Interior trim gap '72
I have wondered for as long as I have had my car, if this condition is correct. There is a space of about a half inch between the forward rubber window seals and the corresponding interior trim piece. Seems odd it would be like that, almost like something is missing or installed incorrectly. The gap is highlighted by the arrows in the attache pic; it is in both left and right sides. Is this just the way it supposed to be? Thanks.
Old May 14, 2014 | 07:29 PM
DUB's Avatar
DUB
YES...the windshield pillar post moldings can be very slightly adjusted. This adjustment will not close the gap. When I am working on one...I want to make sure the area where the front T-top latch will operate without hitting the interior molding...and also fit up with the top center interior trim. The gap at the weatherstrip track ...is what it is....because the pillar post trim stops against the pillar post frame piece....and stops it from getting closer to the weatherstrip track.
DUB
Old May 14, 2014 | 07:56 PM
Alan 71's Avatar
Alan 71
Hi k,
I believe there can be quite an improvement in the reveal between the a-pillar soft trim and the weatherstrip retainer.
It at least should have a uniform reveal it's entire length. Are the top screws in place on the soft trim?
My thought is that it's the soft trim could be the problem, not the weatherstrip.
Check the screws at top of the a-pillar trim, and the velcro type fasteners on the back side of the trim and on the a-pillar itself.
Good Luck!
Regards,
Alan
Old May 15, 2014 | 10:28 AM
kansas123's Avatar
kansas123
Thanks for the suggestions and answers. Will check it out!
Old May 15, 2014 | 01:25 PM
Alan 71's Avatar
Alan 71
Hi k,
I came back and looked at your pictures again and am now leaning towards it being a weatherstrip problem.
I can't see that the weatherstrip retainer is even in place and the top of the weatherstrip (where the roof panel weatherstrip meets it) doesn't seem to be configured correctly.
So???
Regards,
Alan
Old May 15, 2014 | 05:29 PM
kansas123's Avatar
kansas123
Originally Posted by Alan 71
Hi k,
So???
Regards,
Alan
The problem is a bit of both, but mostly how the pillar trim piece is installed, I removed it and attempted to reinstall it, it's a bit stiff and ungiving, but with a little more work I think I can close that gap nearly to nothing; it will look much better. I may wait until after I have a new windshield installed first, I am not sure how much stuff needs to be removed for that to be done yet. I also have new weather strip to install there.
Last edited by kansas123; May 15, 2014 at 05:30 PM. Reason: omitted part of answer
Old May 15, 2014 | 06:03 PM
DUB's Avatar
DUB
kansas123,
Knowing that the molding originally was steel backed. You can try to heat up the vinyl with a heat gun and really warm it up and try to shape it by twisting it...and test fit it as you go until you find what makes you happy.
Trying to get the two "velcro" plastic retainers to actually catch and hold is REALLY FUN. Sometimes that is a loosing battle.
DUB
Old May 15, 2014 | 07:59 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Mine have a similar gap to the OP's. Mine are aftermarket replacements and I just assumed that awful was because of that. I have often though of removing the trim and trying to bend it slightly to close the gap. Just another in the list of stuff I need to do.
To Interior trim gap '72
