Catastrophe averted
Old Jun 5, 2014 | 10:09 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
Default Catastrophe averted
Sometimes rebuilds are necessary, sometimes we do them because "its about time."
I thought I would share my "yikes" moment for the evening.
Old Jun 5, 2014 | 10:26 PM
SHARKBIT77's Avatar
SHARKBIT77
Luck is on your side today my friend.
Old Jun 5, 2014 | 10:33 PM
keithinspace's Avatar
keithinspace
Looks like it's about time to do somethin' about somethin'...
I pulled mine apart for a couple of reasons and as we were removing the components, we started realizing how good the timing was (no pun intended):
---60# valve spring seat pressure (120# is tired...)
---3 bent pushrods...one of them a pretzel
---2 lifters starting to wipe
---Old nylon timing gear waiting to strip
---Several chipped valve crowns
---2 very near blowout points on my head gaskets
This was all on a GM assembled LT-1 engine that was dated between 1976 and 1978. We estimate that the engine hasn't seen 10k miles since put in the car around then, judging by the wall/ring condition
Any one of these things could have created CATASTROPHIC failure inside the engine and I would have been looking for a core block. As it was, I was able to start with a "9 out of 10" 4-bolt main old-school engine for my rebuild.
Score one for catching problems before they're problems. Good job!!!
Old Jun 5, 2014 | 11:46 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
O.K.........I'm getting over the "cold chills" now!
Old Jun 6, 2014 | 12:30 AM
F22's Avatar
F22
Glad you caught it! It truly helps the C3 owner, to know as much as possible, about the nuts, retainers, linkages and on and on, because you caught this ahead of time...
Old Jun 6, 2014 | 02:31 AM
7T1vette's Avatar
7T1vette
No telling how long it's been that way. Amazing that it didn't let go, though. The 'loose' half of that keeper is all that was retaining the other half so that the valve didn't drop. WHEW!!!
Old Jun 6, 2014 | 02:49 AM
mrscott25's Avatar
mrscott25
I don't see what the big deal is...you had at least two or three more revolutions on the motor before that valve dropped. Sheeseh Talk about over reacting! Good catch! Would have been one big
Old Jun 6, 2014 | 04:33 AM
doorgunner's Avatar
doorgunner
I realize it's 3:33 A.M..................
BUT I have to go into the garage and yank a couple valve covers.....
you know.........
just to be safe and all!
Old Jun 6, 2014 | 05:18 AM
vettefred's Avatar
vettefred
Skip Shift
Whoa....you can't get much luckier than that. Would have made a mess for sure.
Fred
Old Jun 6, 2014 | 07:10 AM
Alan 71's Avatar
Alan 71
Hi LMP,
So what you're saying is "what you don't know can't hurt you" may not work in this situation???
Regards,
Alan
Old Jun 6, 2014 | 07:48 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
That gets close to the Had To Change My Shorts category.
Old Jun 6, 2014 | 09:24 AM
LeMans Pete
That's exactly what I was thinking. I had just finished inspecting all the rockers and pushrods when I moved on to valve tips.
There were many minor symptoms that made me start the tear down, I'm glad I made the decision.
Old Jun 6, 2014 | 09:29 AM
LeMans Pete
Originally Posted by Alan 71
Hi LMP,
So what you're say is "what you don't know can't hurt you" may not work in this situation???
Regards,
Alan
Hey Alan,
Indeed. My comb just got a little finer.
There should be a smiley for that.
To Catastrophe averted
