C-3 doors date codes
Old Jun 6, 2014 | 11:26 AM
Chuck-C-80's Avatar
Chuck-C-80
Default C-3 doors date codes
Do C-3 doors have date codes and if so where?
Old Jun 6, 2014 | 12:03 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I don't know that the doors are dated. Original interior trim panels often have dates on them.
Old Jun 6, 2014 | 12:28 PM
Chuck-C-80's Avatar
Chuck-C-80
Thanks Mike, I have seen the date codes on the trim pieces. I removed the door panel for the first time and in chalk the word (SERVICE) was written on the door... ???? I was trying to determine if the door had been replaced.
Old Jun 6, 2014 | 03:23 PM
Alan 71's Avatar
Alan 71
Hi Chuck,
I think one thing that would 'date' a bare door in a way is the presence of the steel crash reinforcement.
I'm not sure just when they appeared… perhaps 1973? I'm pretty sure they weren't part of 71 doors.
You can see the ends of the reinforcement in the door's jambs.
Regards,
Alan
Old Jun 6, 2014 | 04:11 PM
hunt4cleanair's Avatar
hunt4cleanair
Chuck
Keep in mind that the doors were installed when the body went through the paint shop. Up to that point, any reference to part numbers on the body was with the job number...documented on your buildsheet and on the passenger side underbody panel. Yellow grease pencil was used to mark the job number on body panels on the buildup in the body shop...so any numbers on the door would be the same as other body panels. Any deviation you're finding could very well have been a service note once the vehicle left the factory. Of course...it could have meant repair and service during final inspection in the factory.
Hope this helps.
Old Jun 6, 2014 | 05:48 PM
Chuck-C-80's Avatar
Chuck-C-80
Originally Posted by Alan 71
Hi Chuck,
Regards,
Alan
Thanks for the info. I'll take a look.
Old Jun 6, 2014 | 05:53 PM
Chuck-C-80's Avatar
Chuck-C-80
Originally Posted by hunt4cleanair
Chuck
Hope this helps.
So a number like 419 would be a job number? I haven't decided to remove the build sheet. Its there and looks really good but I had an NCRS restorer tell me not to remove it. I really want to take a look at it. Thanks for the info.
Old Jun 7, 2014 | 04:33 AM
hunt4cleanair
Yeah...if you have seen this number hand scrawled...its probably the job number for your 80. The link below is for an excerpt from the buildsheet book on the chapter that describes this assembly process:
Job Numbers & Body Panels
Old Jun 7, 2014 | 09:18 AM
Easy Mike's Avatar
Easy Mike
No need to jerk up your carpet, but peek behind it and see if you find 419 or 19 (shorthand) on the tranny hump passenger side. This one has 25 on it.
Old Jun 7, 2014 | 08:19 PM
Chuck-C-80's Avatar
Chuck-C-80
cool thanks.
To C-3 doors date codes
