Front nose reinforcement
I'm doing a frame-off restoration on my 69', now I'm working on body and I'm stripping everything because most of metal parts are rusted, also front nose reinforcement (between hood and headlights)! Someone know how is it fixed to body?(Glued?) and how to remove it... I don't want to damage fiberglass!
I've seen rivets but I didn't know if they fix the brace to the body or the 2 boxed parts of the brace... Do you know if these rivets has a special head on the outside? I can't see them...I suppose they are under the paint but the thickness isn't so big to suppose hidden rivets heads..
Removing rivets without seeing their heads isn't so easy!
Remove the support stands on each end of this beam. Then ...using a heat gun...begin heating up the fiberglass on the outside of the panel.
Then...when you get it HOT... ( Hot is defined by being so hot you can not hold your hand on it...but not so hot you get it to smoke) you can go in with a thin wedged tool...like flat blade screwdriver or a narrow putty knife and CAREFULLY slide in IN BETWEEN the outer panel and the bonding strip that is riveted to this metal beam. You will know you have it HOT enough when you poke at the exposed adhesive and it is spongy and soft.
Using light pressure....slide the screwdriver/putty knife in and see if the metal beam AND bonding strip show signs of releasing. MAKE SURE you do both sides of the metal beam because it is bonded on the front and rear edges. If you see movement....even a slight bit of movement...keep applying heat further away from the end where you have started. Then...try sliding the screwdriver in a little bit more and see if the gap is widening. If it is....I usually pull out that screwdriver and install one with a lightly thicker tip...and push it in.
Then I take the thinner tipped screwdriver and move a little bit away from the one I have installed ...getting it in the gap I have created an push it in and see if I am getting the gap to open up further.
I keep doing this BECAUSE HEAT IS YOUR FRIEND HERE!!!!
I usually hold my heat gun at an angle so I am also preheating up the area I am heading towards...instead of pointing my heat gun straight at the panel in just one spot. Taking your time and let the HEAT work for you. If you get it right...the beam will come out EASILY without damaging anything at all.
You can if you want...when heating up the top surface...you can blow some heat right on the bonding areas from the underside. Due to your design...I would heat up the outside....because later year models I heat from the underside because they do not have a fiberglass stir riveted to the beam and glued in place.
You could do all the heating form the underside...but it will take a a lot longer due to the thickness of what you have to get the heat to absorb through...to get to the glue that is on the underside of the top hood surround. That is why I am saying to heat from the outside.
JUST BE PATIENT. I have lost count on how many I have removed this way...without any damage.
You can get it hot enough to release the glue without even burning paint. You have to remember that it can be hot on the outside...and the panel hot...but may take a little bit of time to get to the glue and soften it enough to release...which is why I wrote ...BE PATIENT.
DUB
This beam can come out. It will take time and PATIENCE. It is glued onto the underside of the top hood surround panel. The outer ends are bolted in place where the two stands are bolted to the front section of your inner skirts.
DUB
So heat will help to soften the glue, but what about rivets?
http://willcoxcorvette.com/instructi...-1_secured.pdf
I have slight raised areas around the rivets in my survivor 58K miles 72, kind of consider them beauty marks showing its originality.
Thanks,
Mike
Thanks,
Mike
Exactly what I've to do...
DUB
BEFORE you pull this support out. If you put a headlight actuator support back in you will see that the section of the headlight support that contacts this support beam that you plan on removing is flush and tight. Both parts meet each other and are not at angles. when you put this new support beam in ( if that is what you are going to do)...they are the same but different. In regards to the depth. so when the beam is in...and the actuator support is in and tight. you might see that the actuator support is tight against the beam at the back by the hood opening...but forward of that in the width of the new support beam...there may be a gap. So you might need to make shims to bring the actuator support down and make it is when it is all tightened...it is flush.
DUB
So they're fiberglass made?
DUB
They suggest to mantain bonding strip and remove only reinforcement and this should help for fitting problems...if the repro part are almost the same of original (not so sure about it...
