1982 CE pinstripes
Old Jun 22, 2014 | 06:31 PM
Bikergems's Avatar
Bikergems
Default 1982 CE pinstripes
Where can I find pinstripes of 1982 CE. Do not need the full set of pinstripes. Is there an aftermarket stripe that will match?
Old Jun 22, 2014 | 07:11 PM
DUB's Avatar
DUB
I have not found any at all. The color is quite specific. And the way the stripes are cut...laying them out... off a roll just is not correct....that is if you are worried about how the ends of the stripe look where they touch each other at the ends.
DUB
Old Jun 22, 2014 | 07:24 PM
BLUDICE's Avatar
BLUDICE
Find a person who pin stripes with paint (I used to) a good one can lay down some lines that with look original. If the concerns you about using paint - if you don't like it or want to make a change in the future - easy to remove - Easy Off oven cleaner will take it off.
Old Jun 23, 2014 | 02:22 PM
Bikergems's Avatar
Bikergems
Thanks DUB and BLUDICE.
Old Jun 24, 2014 | 10:00 AM
Rotonda's Avatar
Rotonda
http://phoenixgraphix.com/gm/1982cvt2.php
To 1982 CE pinstripes
