1975 carb help!
Old Jul 15, 2014 | 07:18 PM
hicomp's Avatar
hicomp
Default 1975 carb help!
OK, newbie to the forum here. I could use some help with an issue on my 1975 Corvette.
The Car:
1975 L-48, THM 400, stock engine, minor upgrades (aluminum intake), electric fans, aluminum rad, SS exhaust, runs well.
The car developed a fuel leak a couple days ago (good thing I checked after a short drive!). Fuel was sitting on the intake manifold right under the fuel line intake at the carb. So I pulled into the garage and checked it out. Not the fuel line. Not the fuel filter. Upon closer inspection I see a crack in the body of the carb about 1/4 past the nut for the filter. Have no idea how that happened.
I thought, no problem, I have a remanufactured Rochester carb from Ecklers sitting in a box. I had bought it last year and haven't had time to install. Perfect time to install it (great...back on the road in 1 hour!). Wrong...the car runs horrible. I hooked up everything correctly, didn't touch anything else. The engine starts and dies right away. If I give it more throttle to bring the RPM up, it runs but has a bad shake and feels like a cylinder isn't firing. I checked each ignition wire at the plug and the distributor (it's HEI). I even pulled every spark plug and checked for fouling (except #7). The carb is supposed to be "ready to go"...just adjust the idle speed screw! I have adjsut the mixture screws...yet. I might put the old carb on for 5 minutes and see if runs like it used to.
Any ideas what could be wrong? ANY help would be appreciated!
Old Jul 16, 2014 | 12:28 AM
stumpshot's Avatar
stumpshot
Make sure you have the carb to manifold bolts tight and all the gaskets are in place. Check the screws on the carb body to make sure they are down. Check all around the carb for any open pipes that can cause a vacuum leak. Make sure the choke is working right for the temperature of the motor.
Try your old carb and see if you got a crappy rebuild job. After all that you may want to just squirt some JB Weld on the old one and hope for the best.
Good luck!
Roy
Old Jul 16, 2014 | 01:01 AM
hicomp's Avatar
hicomp
Good luck!
Roy
Thanks for the reply. I torqued the carb to manifold bolts to about 100 in-lbs. The reman carb came with a slightly different gasket than what was in the car. I tried both gaskets (the difference in the gaskets was around the idle ports just forward of the primary butterflies)
I haven't check the screws on the carb itself...I figured a new "reman" carb should be good to go (it wasn't cheap). There are no open ports on the carb. For example, I no longer have a heat riser so I've blocked the port with a rubber cap. The choke isn't perfect but I hold the throttle down to keep it running or warm it up. But the shake/vibration is not good. I know the difference between a rough start/idle/miss. Again feels like a cylinder isn't firing. I haven't checked the timing check but I didn't move it. It's frustrating...
Old Jul 16, 2014 | 01:12 AM
dugsgms74's Avatar
dugsgms74
Rebuilt carbs(especially q-jets) are rarely ever "good to go". I recently purchased one from monzon carbs and I had to take it all apart and go through everything before itd run. How it was shipped was a joke, would never have run.
Old Jul 16, 2014 | 01:27 AM
hicomp's Avatar
hicomp
Hmmm...interesting. I suppose I thought a $400 carb (from Ecklers) should work correctly out of the box. I mean, adjusting the idle, high idle and even the mixture screws, sure, but disassembly? Now that I think about it I also noticed that the upper gasket above the bowl was soaked in fuel. I thought that was odd since it's been used on the car for a total of 1 minute.
Old Jul 16, 2014 | 11:29 AM
stumpshot's Avatar
stumpshot
Hicomp----If you pulled more than one plug wire at a time, check them all and make sure they are right (I won't tell you why I know).
Having done that I'd yank the new carb and stick the old one back on to verify it's a carb problem. I have never had any luck with "rebuilt" anything. That's not to say that there aren't rebuilders who do good work, just my type of Corvette luck.
Roy
Old Jul 16, 2014 | 03:26 PM
dochorsepower's Avatar
dochorsepower
Wet gasket could be improper float setting. Check the forum for other thread replies by Lars, he seems to be the Q-jet fountain of knowledge.
Old Jul 16, 2014 | 05:56 PM
hicomp's Avatar
hicomp
[QUOTE=stumpshot;1587373275]Hicomp----If you pulled more than one plug wire at a time, check them all and make sure they are right (I won't tell you why I know).
Roy[/QUOTE
I don't usually like rebuilt either but I wanted to keep a Rochester and pretty sure they don't make new ones. As far as the wires go, I only pulled one at a time. I also check the connections at the cap to ensure the firing order was correct.
I do plan to swap the old carb back and see what happens, hopefully tonight.
Thanks for the input.
Old Jul 16, 2014 | 06:02 PM
hicomp's Avatar
hicomp
Stumpshot suggested I check the carb screws for tightness. A float could be possible. I plan to swap the old carb back and see what happens. If it runs as it did before, I'll be opening up my "rebuilt" $400 carb for a look. Its been a while since I actually tinkered with a carb (when they run right, I leave it alone!).
Before I joined the forum I did some searching saw many references to Lars as a wizard with Rochesters.
Old Jul 18, 2014 | 07:00 PM
hicomp's Avatar
hicomp
OK you were correct, it's the reman carb. I removed the reman carb, put the old carb back on, and it ran smooth as before.
Now that I know the issue is the reman carb, I reinstalled it and started the car. I warmed up the engine to operating temperature and managed to get it idling (very rough) but the choke was not fully off. I manually opened the choke plate fully and it wanted to stall. Then I turned up the idle screw and it ran but rough again. Also, as you increase the RPM it still misses but not as badly. Now I am unsure how to procede.
Old Jul 19, 2014 | 01:31 PM
Alwyn678's Avatar
Alwyn678
Old Jul 20, 2014 | 06:24 PM
lars's Avatar
lars
I've posted quite a few threads here on this Forum warning about Commercially rebuilt carbs ("remanufactured" carbs). They are seldom good for anything other than as a doorstop. Your carb will have a series of significant issues that can only be corrected by swapping good parts off of a couple of original "donor" carbs. Here is a summary of a few of the articles I've posted so you get an idea of what you're up against:
Problems I have Seen with Commercially Rebuilt Q-Jets
by Lars Grimsrud
©2014 Lars Grimsrud.
This article may not be published or distributed without the written permission of the author
Introduction
As the Q-Jet carbs keep getting older, fewer and fewer are original carbs that have not been tampered with or altered. Rebuilding a Q-Jet is becoming a significant problem for the novice, because the carbs cannot be simply bolted together the way they came apart: The carbs have been altered, and these alterations must be identified and corrected before the carb will run as it was designed to do.
The carbs with the most significant amount of problems and alterations are the “commercially rebuilt” carbs. These are carbs which have been through assembly-line type rebuild operations by unskilled workers. Every carb is altered and modified to produce a semi-consistent, “generic” level of performance to limit the warranty claims against the rebuilder, and carbs are often built with a mix-match of parts from various years: You may have a “correct” ’72 Chevy carb number on the float bowl, but the throttle plate could be from a ’66 Buick with a Chevy throttle lever screwed in place, and the airhorn may be from a ’69 Chevy truck. As a result, you get a carb that performs marginally well or just moderately bad (and sometimes, really bad). Repairing one of these carbs can be a costly experience, since Q-Jet replacement parts have been discontinued by all sources: You have to buy a few “parts carbs” to get the repair parts needed. Examples of commercially rebuilt carbs are carbs procured from Checker Auto Parts, NAPA, AutoZone, Jeg’s, and carbs rebuilt by name-brand suppliers such as Holley. Most commercial carbs can be easily identified by a paper sticker placed on the carb body near the rear, driver’s side corner. You can also identify most of them by the bead-blasted appearance which will have removed all plating and color from the carb and components (often leaving all of the steel linkage parts rusty). Most commercially rebuilt carbs have a blocking baffle pressed into the bowl vent hole located just forward of the air cleaner stud hole (so you won’t try to stick the stud down the vent hole and damage the float) – a non-commercial carb has no obstruction at all in the vent hole. Many commercial builders also install Phillips-head screws in the carb or use silver zinc plated hardware– a sure-fire give-away of a commercial carb (correct screws are black slotted head screws).
The following article consists of two “postings” I did on the CorvetteForum a few years ago after tearing down some commercially rebuilt carbs, along with some findings from a third carb I just finished setting up. These are my findings and comments. Be aware of all of these potential problems on any commercially rebuilt Q-Jet you come across.
Posting #1:
Forum member "Bobs77vet" (Bob K) sent me a carb he procured via the internet (correct me if I'm wrong, Bob, but I think it was an eBay purchase or something similar). I want to use Bob's carb as an example of all the things that can be wrong with a carb, and why you simply can't just disassemble a Q-Jet, slap a kit in it, put it back together, and expect it to run right.
In all my papers and postings, I always warn people against buying "commercially rebuilt carbs," and I keep getting the question from people, "What's wrong with a commercially rebuilt carb?"
Bob's carb was a commercially rebuilt carb that had been recently rebuilt by a "commercial carb builder." Whoever bought it put it right back up for sale...
Here are the issues I found with this "near-new" 1975 Q-Jet rebuild and some of the things that had to be done to fix it:
1. Bent APT needle. Also called the "altitude compensator," this device controls part-throttle mixture using an adjustable needle in a 3rd "jet" in the float bowl. The needle had been bent during rebuilt, causing the needle to not be engaged in the jet. This resulted in a "full rich" condition that somebody tried to compensate for with other "tuning" methods. Read on...
2. Lead plugs installed in idle air bleed holes. This is a common practice by most commercial builders. The Q-Jet uses an idle air bleed system that allows idle air to be pulled into the intake just below the throttle blades. By allowing a controlled amount of air to bypass the throttle blades, the throttle blade opening can be decreased, allowing effective use of the transition slots in the throttle plate. Plugging the holes for the idle air bleed results in the idle speed screw needing to be cranked up to the point that the transition slots are excessively exposed, causing off-idle stumble and hesitation.
3. Extreme rich jetted - damaged #78 jets. To compensate for other setup issues, the builder had installed #78 jets in a carb that should have #72 jets. In addition, they had slipped a bit with the screwdriver during assembly, damaging the jets and the fuel flow.
4. Throttle plate loose. The screws attaching the throttle plate to the fuel bowl were loose due to the factory-installed lock washers being deleted. This caused vacuum leaks at the throttle plate and a lean condition.
5. Severely bent primary throttle shaft & lever. The primary throttle shaft was bent, causing binding and sticking of the throttle.
6. Stripped inlet threads. Common problem on a Q-Jet. But in this case, the builder had installed a self-threading oversized inlet fitting, deleted the fuel filter and filter spring, and polluted the carb with metal debris from the self-tapping fitting.
7. Bent & destroyed secondary lockout lever. In an attempt to "adjust" the secondary lockout lever, the builder had bent the lever to the point of breaking the tang off the lower portion of the lever. The secondary engagement tang was broken, and the rest of the lever was severely bent and unusable.
8. Sandblasted finish. Common practice with the commercial builders: The entire carb had been sandblasted, removing and destroying all finishes and corrosion protection on aluminum and steel surfaces. Result is that aluminum surfaces are covered in white oxidation, and all steel parts are badly rusted. The carb had to be acid dipped and chemical conversion coated to bring back some of its correct finish.
9. Secondary airvalve loose & sticking. The builder had ground the staked feature of the retaining screws off, resulting in the screws loosening and jamming the airvalve.
10. Incorrect float installed. Brass floats don't cut it on a Q-Jet. Always use a NitroFill float.
11. Extreme low float level (.620"). To compensate for other issues, the float level had been dropped to an extreme .620" level. Correct level is .420. This low float level assured that the carb would not operate on the idle circuit, and the carb was idling on the main discharge circuit once the idle speed screw was turned in far enough.
12. Incorrect power piston spring. Common commercial rebuild problem: They install a "generic" power piston spring. This may work okay on a truck, but it sure doesn't work on a Vette. GM just discontinued the "Corvette" power piston springs...
13. Stripped threads in bowl for throttle body attach screws. Another common problem with these carbs is that they tighten the screws so far that the threads strip out. You have to have a handful of 10-32 HeliCoils any time you try to rebuild a commercial carb.
14. Bent primary rods. The tips of the primary rods were bent from incorrect attempt at installation into the jets. This eliminated any fuel metering control.
15. Accel pump rod broken. The commercial builders use junk parts from junk carbs. The rod attached to the accel pump lever was broken off at the top "jog," and the builder just installed a snap retainer rather than replacing the rod.
16. Bent primary throttle blades. In an attempt to get the throttle geometry right, the builder actually bent the primary throttle blades at an angle. This resulted in the primary throttles not fully closing. With the way the rest of the carb was set up, this was probably irrelevant, since the carb needed all the throttle opening it could get to idle at all..
17. Secondary throttles set to open over-center. Another common "speed trick." The secondary throttle on a Q-Jet should not open past vertical. In fact, they need to stop just short of vertical in order to produce most effective airflow through the secondary side.
18. Broken throttle plate. A common issue on the commercial carbs is that the builders install throttle shaft bushings in these carbs, whether they're needed or not. Very few Q-Jets really need throttle shaft bushings, and most people who install them screw up the install. In this case, the builder bored the throttle plate for oversized bushings and broke the throttle plate in the process. No problem - they just smacked the bushings into the broken throttle plate, left the massive vacuum leak unresolved, and let 'er go. The plate had to be repaired with correctly installed K-Liner type bushings.
19. Plugged idle fuel tubes. The smallest metering orifaces in a Q-Jet are the Idle Fuel Transfer Tubes. These tubes are pressed into the carb, and only the top oriface of the tube is visible in the top of the float bowl adjacent to the venturies. Commercial builders often pull these tubes out and install "generic" tubes with incorrect orifices in the top and bottom of the tubes to compensate for the other "tricks" they do to the carb. In this case, the builder had installed tubes with lower orifices too small, and these had been plugged up with the metal debris from the oversized inlet fitting. There was no idle fuel flow possible.
These commercial carbs obviously create some unique tuning and setup problems, and they are contributing to the notion that "Q-Jets are junk," since they never run right. If you have one of these carbs, be sure you look critically at every aspect of the carb during any setup and rebuild process - you cannot simply "install a carb kit" in one of these carbs and have it run right...
Posting #2:
As most of you know, I've been warning people about the problems with the commercially-rebuilt Q-Jet carbs from various sources. The commercial rebuilders do some really odd things with Q-Jets, and set them up so that many of them simply don't run. Many of the modifications are such that a rookie Corvette handy-guy would not be able to fix these issues with a "carb kit" rebuild, resulting in a myriad of bizarre drivability problems and a bad rap for the Q-Jet carbs.
A couple of weeks ago, I posted some results from the teardown and inspection of "Bobs77" carb. This week, I have a Q-Jet belonging to Jim from MA. This carb has been "remanufactured" by Holley, so let's take a look at how Holley set this carb up...
Carb: 7044202 (1974 350 Chevy)
Should be set up and jetted with 75 primary jets, 46 primary rods, and the "CH" secondary rods (.057"). Pretty standard jetting.
Here are the issues I found:
1. Stripped fuel inlet. The inlet threads were stripped out and a self-tapping inlet fitting had been installed. Bad way to repair a bad inlet, since these self-tapping fittings can easily tear the rest of the threads out. Repair: Machine and tap the inlet for a stainless steel helical insert.
2. Sticking secondary airvalve. The airhorn casting was distorted at the rear edge of the airvalve from over-torquing of the rear airhorn screws, resulting in jamming and sticking of the airvalve. Repair: File the displaced metal from the airhorn to obtain correct clearance to the airvalve.
3. Bent accel pump lever. The lever had been bent to better align with the accel pump lever rod (see next item). The bend looked "factory", but Q-Jet levers are straight... Repair: Straighten the lever.
4. Accel pump lever rod cut off. The "jog" on the top of the rod had been cut off and an odd retainer had been used to keep the rod in the lever. This slightly changed the geometry of things, requiring the lever to be bent. Repair: Replace the rod.
5. Bent secondary airvalve linkage & lever. The airvalve linkage system had some very odd, creative bends in it. It might look factory if you hadn't seen one before, but this just wasn't right. Repair: Bend it all back to match a "virgin" carb I had sitting here in the shop.
6. Incorrect vacuum nipples. Some very odd configuration vacuum nipples had been installed in the carb. Repair: Replace vacuum nipples with correct, stock nipples.
7. Warped airhorn. Holley had installed a big, fat airhorn gasket to compensate for a severely bent airhorn. Even with the fat gasket, the fuel transfer passages were not sealing - the idle circuit was not getting fuel on this carb. Repair: Straighten and machine the airhorn flat.
8. Incorrect secondary rods. Holley had installed a set of "generic" .040" diameter rods. Repair: Install the correct .057" Corvette rods.
9. Power piston installed without primary rods engaged in jets, bending and destroying both primary rods. Power piston was inoperative. No kidding: When the power piston was installed, they missed installation of the rods and simply jammed the airhorn down on top of the thing. This folded the rods over in the bottom of the float bowl, breaking one rod and destroying the other. The rods were not installed in the jets, resulting in an extreme rich condition. Repair: Replace the rods with OEM rods of the right size.
10. Accel pump jammed in bore - inoperative. When the accel pump was installed, it was installed "dry" with no lube. This resulted in the accel pump cup turning itself inside-out against the accel pump wall and jamming the pump into the bottom of the bore. The accel pump was completely inoperative. Repair: Replace accel pump and install correctly.
11. Very high float level. Float level on this carb should be about .375". Float level was set at .200" - too high for a street driven application. Repair: Replace the float and set to .375".
12. Float clip installed backwards. The clip attaching the needle to the float must be installed around the rear edge of the float arm in order to avoid binding the needle in the seat. The clip was installed around the forward edge. There was a GM Service Bulletin on this issue in the late 60's. Repair: Install the new needle clip the right way.
13. Idle air bleed holes plugged with lead plugs. The holes in the float bowl that transfer air to the idle air bleed holes below the throttle blades had been intentionally plugged with lead plugs, making the idle air bleed system inoperative. When this is inoperative, the idle speed screw must be cranked in a lot further, resulting in excessive exposure of the transition slots. This, again, will result in stumbles and off-idle hesitations. Repair: Knock the lead plugs out of the holes with a pin punch and hammer.
14. Incorrect power piston spring. I don't know where Holley got this thing from, but it looked like the front spring off of a 3/4 ton truck. In order to spot incorrect springs, you have to know the correct part number for the right spring, and have some of the "correct" springs on hand for comparison purposes. Repair: Replace the spring with the correct OEM spring.
15. Idle mixture screws fully closed. This was likely not done by Holley. With all the problems with this carb, it would have run incredibly rich. The installer tried to lean it out by closing the idle mixture screws. I doubt this fixed the problem... Repair: Correctly set idle mixture screws during setup and test running to 2 turns out.
16. Incorrect springs on mixture screws. Long springs had been installed on the screws, resulting in the springs being in coil bind upon closing the screws. Repair: Install the correct short springs from a donor carb.
17. Fuel filter spring missing. The self-tapping inlet did not allow for a spring to be installed. The filter was installed with no backing spring, which means that the fuel was simply by-passing the filter. Repair: Install a spring.
18. Power piston stop pin cut off - piston destroyed. This is a favorite "trick" by many of the builders, and Holley always does this: The lower stop pin on the power piston, which determines how deep the power piston rides at cruise (and how far the rods engage in the jets to lean the carb out at cruise), had been cut off. This makes the rods ride way too deep in the jets, running the carb very lean. Repair: Find a virgin piston out of a donor carb and replace the piston.
19. Extreme lean jetted. The carb was jetted with #71 jets. If the rods had been installed in the jets, the carb would have run extremely lean, especially with the pin cut off the power piston. Without the rods in the jets, it ran incredible rich. Repair: Jet the carb correctly per spec.
20. One secondary discharge tube missing. On the secondary side, fuel is discharged out of two 1/4" diameter tubes sticking out of the airhorn. One of these tubes was never installed in the carb, resulting in little or no fuel discharge on the secondary side. Repair: Pull the tube out of a donor carb and install it in the carb.
Another Carb I Just Rebuilt:
This carb came in for rebuild from Forum member “Young69Owner.” It was a commercially rebuilt carb, of the type you’d get from AutoZone or Checker. Adam’s complaints were an erratic idle and leaking gas.
Carb number 7044203 (1974 Chevy 350 Truck sold as a ’69 Vette carb)
Here is what I found with the carb:
1. Carb was commercially rebuilt - typical of an AutoZone or Checker Auto type carb. It had been sandblasted and stripped of all protective coatings, and it had been assembled using mismatched junk parts. Repair: Replace all mismatched and junk parts with parts from donor carbs. Acid dip the good parts to remove corrosion. Chemical conversion coat to restore some original color back to the carb.
2. The divorced choke coil sent with the carb had been destroyed - it had been bent to keep the choke closed under all conditions, possibly in an attempt to compensate for the other problems listed below… Repair: Have owner order a new reproduction divorced choke coil from Paragon.
3. The throttle lever was bent and binding. Repair: Since the entire throttle plate was incorrect for the carb, it was replaced (see item #20).
4. The entire choke mounting plate was loose. If this had been the only choke problem, it could have caused erratic choke function. Repair: Since the entire choke mounting plate and choke system was incorrect for the carb it was replaced (see item #21).
5. The secondary airvalve windup spring was set way too loose, resulting in premature secondary opening and a likely stumble or sag going into the secondaries. Repair: Since the entire airhorn was incorrect for the carb, the complete assembly was replaced and the airvalve on the new assembly was set correctly (see item #24).
6. The base gaskets used with the carb were incorrect for the manifold in use – the engine probably had a base gasket leak. Repair: Correct base gasket was provided with the carb.
7. Bent/destroyed accel pump rod. Someone had bent the rod and destroyed it to remove the airhorn off the carb. Repair: Replace rod with a good used rod from a donor carb.
8. Bent/destroyed choke intermediate rod. The rod had been severely bent and modified in an attempt to alter choke operation. Repair: Replace rod with a good used rod from a donor carb.
9. Secondary rod hanger had been bent and destroyed – jamming the hanger against airhorn. Repair: Replace with hanger from donor carb.
10. The commercial rebuilder had removed the original secondary rods and replaced them with brass, generic, "no-size" "no-stamp" rods. They were not of the correct dimensions, and were producing faulty secondary fuel metering. Repair: Replace the rods with correct, OEM rods from a donor carb.
11. The power piston had been cut off and destroyed with a pair of side cutters. Repair: Replace the power piston with a correct, OEM piston from a donor carb.
12. The primary rods had been removed and replaced with generic "no-size" "no-stamp" rods (approx #42), really screwing up cruise mixture. Repair: Replace the rods with correct, OEM rods from a donor carb of a size suitable for the engine mods (headers, free-flowing exhaust and a good intake require a slight increase in fuel flow).
13. The air cleaner stud had been broken off and seized in the float bowl. Repair: Since the entire airhorn was incorrect for the carb, the complete assembly was replaced (see item #24).
14. The float was jamming against the float bowl casting, locking the float in the fully raised position. Repair: Replace float with a correct float for the application.
15. Primary metering jets had been replaced with generic "no-size" jets, adversely affecting mixture. Repair: Replace jets with correct jets for the application.
16. Needle/seat had been stripped out of the float bowl and repaired with a low-flow, press-in seat. Repair: The float bowl was machined, a Helicoil was installed, and the correct, high-flow needle/seat was installed.
17. Incorrect power piston spring was installed – it was so soft that the power piston probably never went into the power enrichment mode. Repair: Install correct, OEM power piston spring for vehicle application.
18. Defective aftermarket brass inlet fitting installed - the sealing cone was defective and would not allow fuel line to seal properly. Repair: Replace fuel inlet fitting with a correct, OEM inlet.
19. Incorrect Holley fuel filter installed. Repair: Install correct inlet filter.
20. Throttle plate ("carb baseplate") was incorrect for the model/series carb. Chevy throttle lever had been cut off a donor carb and screwed to this non-Chevy throttle plate. Fuel transfer holes in the throttle plate did not align with the float bowl, contributing to an erratic idle. Repair: Replace entire throttle plate with correct Chevy throttle plate for the ’74 float bowl from a donor carb.
21. Entire choke pulloff mounting plate, fast idle system, and choke system was off of a mid-60's Buick or Olds – was not compatible with the ‘74 Chevy carb. Repair: Replace entire choke system with parts from a donor carb.
22. Incorrect idle mixture screws - did not fit throttle plate and could not regulate idle fuel flow. Repair: Install correct idle mixture screws in the “new” throttle plate.
23. Idle air bleed holes in the float bowl had been plugged with epoxy. Repair: Knock the epoxy out of the holes to restore correct idle air flow operation.
24. Incorrect airhorn ("top of carburetor") for model/series carb. Incompatible with '74 choke and airvalve system. Repair: Replace entire airhorn with a correct ’74 airhorn from a donor carb.
25. Warped float bowl. Repair: Straighten to fit and seal against “new” airhorn and throttle plate.
Other problems I’m seeing a lot of:
A very common complaint on the commercially-rebuilt carbs is that they “won’t idle.” I also see that they’ll only idle with significant “drippage” out of the primary discharge nozzles at idle, rendering the idle mixture screws ineffective. The primary cause for this is that the commercial builder has removed all of the air bleeds out of the carb: A Q-Jet, like any other carb, uses high speed and low speed air bleeds to slightly emulsify the fuel before it discharges, and to help control fuel mixture through the metering range. The commercial builders will remove these calibrated brass orifices from the carb, leaving the carb running full lean on the idle & transition circuits, and running very lean into the main metering circuit, regardless of what jetting is used. Since these parts are not available from any source, and since the spec size of the orifices is not published, it is very difficult to repair this condition. If all the air bleeds are missing, you’re best off using the carb as a parts carb. Your other option is to buy some brass round stock, chuck it up in a lathe, and start building custom metering parts to press into the carb casting. Most of the bleeds can be made with #53 diameter holes in them as a good starting point, but it’s not possible to tune these “correctly” without actually dyno-running the carb to observe the fuel curve.
So watch out for those commercial carbs, and look critically at every aspect of them if you ever find yourself rebuilding one.
Keep on tuning those Vettes & Musclecars!
Lars
Old Jul 20, 2014 | 08:15 PM
jnb5101's Avatar
jnb5101
As a sidelight to Lars's statements, I can recommend that anyone needing a carb look to ebay. Yes, I said ebay. In the last three months I have scored an unmolested 17057504 for $45 and a 17059222 for $19. Neither carb had ever been opened. Both were really ugly, but that was the tip off. They had been sitting around for decades and Bubba hadn't gotten to them. Follow Lars' excellent papers and you'll have a great running carb.
Old Jul 20, 2014 | 08:36 PM
Sharkster's Avatar
Sharkster
Default Help me Lar's
I tried to PM you but your box is full. I wanted to know if you could rebuild my 75 L82 auto carb?
Old Jul 20, 2014 | 08:46 PM
lars's Avatar
lars
I don't IM, PM, LinkedIn, FaceBook, or Twitter, and I have text blocking on my phone. I e-mail. Just drop me a note.
Lars
V8FastCars@msn.com
Old Jul 30, 2014 | 06:06 PM
hicomp's Avatar
hicomp
Lars[/QUOTE]
Thanks for the reply Lars...much appreciated!!! Wow, I kinda feel ripped off. $500 for a carb (actually, even more for me because I am north of the 49th) and it could/does/might have a myriad of problems. What a joke.
Fortunately, I have my original carb from my '75 but it has a split/crack on the fuel filter housing which is why I replaced it in the first place. Perhaps I can salvage some parts from it. I also have at least one other spare Q-jet in the garage that I could use for parts (I might even bolt it the car and try it).
Hopefully tonight I can get it in the garage. If so, I will
1.Check the timing.
2.Adjust idle screw and mixture screws on the reman carb. This may be futile but it's worth a try as it is still bolted to the car.
3.Swap the spare Q-jet on...it was off 350 Chevy crate engine I installed in another vehicle and ran fine but it's been sitting for a few years.
4.Ask you to rebuild my carb!
If I can get the car idling and running half decent I will be happy as summer is disappearing quickly (the "nice" weather doesn't last long in Canada). And as much as I would like to rebuild/repair the reman carb, I just don't have the time anymore (hence the reman carb). But hey, live and learn!
Thanks again for the response!
Old Jan 31, 2016 | 06:26 AM
jmgpvette's Avatar
jmgpvette
7th Gear
Default i have a Qjet 17059222 that you could rebuild for me! text me at 7272477747 or email
Hi i was wondering if 7 can have you rebuild my Qjet 17059222 that is actually on my 78 vette . Upper gasket is wet and the car is running very rich with gas mileage of 11mpg and the neighbours can smell the fume and gas
you can text me at 7272477747
thanks
George
by Lars Grimsrud
Introduction
Posting #1:
Posting #2:
Lars[/QUOTE]
To 1975 carb help!
Old Jan 31, 2016 | 09:25 AM
'75's Avatar
'75
thanks
George
You will have to e-mail Lars directly to get a response, V8fastcars@msn.com
Old May 23, 2021 | 01:02 PM
Roger Walling's Avatar
Roger Walling
As R66 said, your choke is wired open. It looks like the manual choke wire is broken or stuck.
Thak it to a mechanic and he will have it purring in an hour.
Old May 23, 2021 | 02:31 PM
lars's Avatar
lars
5 year old post - he's probably got it figured out by now...Let it die...
