Corvette Winter Storage ?
Old Sep 13, 2014 | 08:41 PM
Mike Ward's Avatar
Mike Ward
Originally Posted by PeteL46
You mentioned moisture; many years ago I purchased a "Bag It". It's a non-breathable envelope style cover. It has zippers on three side. I do most of the things described above, unzip the bag, open it up and drive the car on it. It instructs you to put desiccant under the car and inside. I put a light cloth cover on first and zip it up. It come out as clean as it went in
Excess moisture is not a problem during winter time in Canada. If anything, a bag might trap some inside.
Old Sep 14, 2014 | 12:49 AM
briankeery's Avatar
briankeery
Originally Posted by LS4 PILOT
Solution.....
Move south ...away from polar bears and that stuff...
I might put the top up Jan . Till late March.
South????? Have you seen the roads in Mexico?????
Old Sep 14, 2014 | 02:46 AM
7T1vette's Avatar
7T1vette
If it will get really cold for prolonged periods, you would do better to make sure the battery is fully charged, then remove it and place it somewhere in a warmer area. If you place it on a floor, make sure there is a non-conductive vapor barrier under the battery. If you want, you can put a battery tender on it there. Being unused in very cold weather is not good for the battery. Keep it above freezing (if you can) and charged up.
Old Sep 14, 2014 | 08:14 AM
C7 Heavn's Avatar
C7 Heavn
3rd Gear
Default Tire Pressure
Lot's of great advice. What do you do about tire pressure - overinflate, underinflate, no change? Should I make semi-circle bloscks to nestle the tire during the Winters? At almost $500 a piece, the tires are precious. Getting cold in Michigan.
Old Sep 14, 2014 | 08:54 AM
Paul L's Avatar
Paul L
Leave the pressures as per normal. Flatspotting goes back to the days of nylon cord, bias-ply tires. Long gone. You don't have to block them.
Old Sep 14, 2014 | 09:09 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I top the gas tanks off, change the oil and wait for the first opportunity to drive if the roads are clear and dry. I've usually been able to sneak them out at least a couple of times a winter.
Old Sep 14, 2014 | 10:04 AM
7T1vette's Avatar
7T1vette
If you are able to drive it some during the winter, that would make a case for keeping the battery in the car and putting a battery tender on it....maybe even a battery warmer.
Driving the car to minimize 'dead' time is always good for the car--as long as you drive it far/long enough to get it up to normal operating temps and get all condensation out of the crankcase & pipes/mufflers. Keeping gas tank full will keep condensation minimized in the tank.
Old Sep 14, 2014 | 10:33 AM
Ontario73's Avatar
Ontario73
Have you ever been to Canada in the winter? Think 3' of snow that doesn't melt until March!
Old Sep 14, 2014 | 01:41 PM
adsvette's Avatar
adsvette
Hi Pete;
Where do you get a large enough quantity of desiccant, all I can find are retail for small packs.
Thanks,
David
Old Sep 14, 2014 | 02:08 PM
adsvette's Avatar
adsvette
Good point, dryness is most often the issue.
I agree about the bag idea, I think the car has to be able to breath. I have a cheap CT dust cover that covers the Corvette right down to the wheels.
My garage is a temporary one, so called portable 12x24 ft. I have new tarps on the ground to reduce moisture as an added measure. We're on 12 feet deep sand here which gets very dry at the surface. My concerns for moisture may be overkill, but I would rather be on the safe side until I get through my first winter. After what we had last year who knows what it will be this year, it's unpredictable.
A lot of good points to consider.
Thanks,
David
Old Sep 14, 2014 | 02:34 PM
Ontario73's Avatar
Ontario73
Originally Posted by adsvette
Hi Pete;
Thanks,
David
Any place that sells boat supplies including Canadian Tire. They have large containers for a reasonable price, but, you may not really need it.
Tim
Old Sep 14, 2014 | 03:10 PM
adsvette's Avatar
adsvette
Hi Guys;
Since we are on moisture related concerns, do any of you have electronic rust protection installed ?
We had one installed by our GM Dealer on our 2009 Buick Allure and it has worked very well.
Five years isn't a long enough bench mark, but is promising so far.
Thanks,
David
Old Sep 14, 2014 | 07:47 PM
  #33
hotrodnick's Avatar
hotrodnick
Here's my list
lube, oil, filter
wash & vacuum
Park on old carpet (my p/u tarp and carpet samples)
Fresh Cab in places you don't want critters. (available at JD dealers, maybe others)
winterize camper
bowl on league
square and round dance
that's my winter
Old Sep 14, 2014 | 07:58 PM
  #34
Dodosmike's Avatar
Dodosmike
Anybody disconnect the fuel line and run the carb dry of fuel? Or is stabilizer sufficient?
This is my first year for cold storage, car is usually heated, but have different stuff that needs heated this winter.
Check the coolant mix. Make sure it's good for -40 or so. Nobody likes a cracked block. ( now I've jinxed myself)
Dodosmike
(Frost here this morning)
Old Sep 14, 2014 | 08:07 PM
  #35
briankeery's Avatar
briankeery
March.........last spring that crap didn't leave my yard until May 14th!!!!!
Old Sep 14, 2014 | 08:40 PM
  #36
hotrodnick's Avatar
hotrodnick
Dodosmike
Stabil works well, I like Startron it also treats the ethanol to keep the moisture molecules suspended.
Old Sep 14, 2014 | 08:42 PM
  #37
Mike Ward's Avatar
Mike Ward
Neither is required.
To Corvette Winter Storage ?
Old Sep 14, 2014 | 08:48 PM
  #38
7T1vette's Avatar
7T1vette
Neither is harmful, either...
Having a full fuel tank is the more important issue.
Old Sep 14, 2014 | 08:59 PM
  #39
hotrodnick's Avatar
hotrodnick
Old Sep 14, 2014 | 09:10 PM
  #40
pacecar620's Avatar
pacecar620
Hi Guys;
Re: 1979 Corvette
What do you do to store your corvette in winter in a unheated garage ?
I'm in Ontario, Canada. January and February get very cold at times.
My main goal is to keep it dry and avoid possible freezing damage.
I'll make sure anti-freeze, other fluids, etc. are good.
Do you plug in a block heater ?
What about dampness, do you use a drying agent ?
Do you drain the Gas tank (or is that unnecessary) ?
Appreciate your thoughts.
Thanks,
David
I'm probably not qualified to answer that!
Full gas tank with a shot of Sta-Bil, disconnect the neg. battery terminal, check your anti-freeze, oil and filter change in the spring and you should be good to go. Forget fogging the cylinders and all that nonsense.
