2 - 2 &1/2" (mandrel-bent pipes only) into a single 3 1/2" is exactly what we used on a restricted class stock car.
With a high-flow cat it can be far better than an OEM original exhaust if there is room for it. IMHO
Would this flunk a visual inspection ?
We had to use iron manifolds too and 'vette ramhorns filled the bill nicely.
Do you any options for better manifolds or exempt headers ?
You may not make great improvements - but you may be able to make some.
I believe Hedman makes a set of full length headers which are CARB legal, but just how effective would they be going through a 2-1-2 exhaust system? As far as the visual inspection is concerned, I think that depends on the smog tech's experience. I don't think many smog techs today know much about older (carbureted)cars. That may be a bit of an advantage for us.
OH yes, full length headers with a great two into one will be very effective - if sized correctly.
It has potential to be better than duals in some respects.
I'm running 68301-6s on mine. I can't remember if the -6 is for the ceramic coating or for the AIR tubes. They've been on the car since 2002 or 2003 and through plenty of smog checks. I'd probably get them painted black and have the ceramic coating done locally if I did it again. Well, I had them re-coated in a "titanium" color when I did my new engine, anyways.
If you used larger mandrel bent pipes and high flow cat and high flow muffler it sure would help. I think dougs try y's are carb legal. The trick in your case is getting the most through the induction and out the exhaust with approved parts while passing a pipe test, if the exhaust were larger with high flow accessories would it pass the visual provided it were run in the same places? Would the high flow cat do enough to pass the pipe test? I think with the combination and placement of parts you could get an honest emmisons legal 375 to 400 horse. my vette passed the pipe test with 260 rwhp, but i had to take it to the ref station because it didn't pass the visual and this was with a flat tapper cam, not the best edelbrock heads and the Wieand action plus that was crappy but made hood clearence all through Hooker comps as 2.5" duals. With Afrs and a roller it might have made 280 or 290.
This is the Flowmaster setup I have on now; the collectors look very similar to the Brzezinski 2 into 1 exhaust system and all the pipes are mandrel bent as well. It is a very well made system, the pipe diameter is 2 1/2" throughout. I like the idea of a better rams horn or shorty headers, but I have to be able to install the A.I.R. plumbing as well.
oops!
With AFR's and a roller it might have easily made 325, not just peak but NOTICABLY more power throughout the entire powerband.
just a thought, you could cut the A.I.R tubes off of a late c3 with tubular manifolds , drill some holes and weld them to a set of long tubes.
that would make them look right at least . no reason it wouldn't work.
Oh I agree, but not to send the wrong message so that the guy that puts that combo on the dyno doesn't get disappointed being as I'd never dyno'd that combo.
What is the intermediate pipe and cat diameter ? I'd consider 3 1/2" to be a minimum, if using 3" - you'd be best to make it and the cat as short of a run as possible, ( and that would still be a cork !).
Those "shorty" style headers are not much better than manifolds - if any, I'd always want full length and even use them on work trucks when possible.
Reason: more
