Advancing Camshaft
Old Sep 15, 2014 | 05:39 PM
Joe Papa's Avatar
Joe Papa
Default Advancing Camshaft
Would there be any advantage to advancing the camshaft 4 degrees in an 1980 L82 with an automatic transmission (TH350c)? Most of the power comes on above 3k rpm and is rather soft below. I have already recurved the distributor and replaced the exhaust system with a Flow Master unit and high flow cat converter; got to keep it looking smog legal in California . Should I replace the heads, more so for higher compression rather than better breathing?
Old Sep 15, 2014 | 05:57 PM
REELAV8R's Avatar
REELAV8R
If you only have to keep it looking smog compliant then you have more freedom to do what you want.
Replacing the heads for more compression would require determining the condition of the rings first. So a leak down test would be the best way to do that.
If you up the compression with weak ring seal you'll be blowing smoke from oil burning after the bump.
Advancing the cam 4* may help with that cam. I'd give it a shot if you got the time and know how. Replace timing chain set while your at it if it's still stock.
Is the Q-jet (?) still stock configuration. If so a good rebuild can do wonders for performance from it as well.
Old Sep 15, 2014 | 07:37 PM
Joe Papa's Avatar
Joe Papa
The engine was rebuilt from a previous owner; it does not use oil nor is there any blow by. The carb has been rebuilt also, and then again by myself. I do not know what went into the rebuild nor do I know actually what camshaft has been installed. The engine idle is a bit lopey and produces about 14 inches of vacuum at idle with initial timing set at 16* . The engine came with a cast iron intake manifold, so I replaced it with an Edelbrock performer. There are no engine numbers on the pad where they should be. The heads appear to be the 882 castings with the large valves. EGR is disconnected and there is no audible signs of pinging or knocking using 89 octane fuel. I need to replace the radiator at some time and thought this would be a good time to do it if it would help.
Old Sep 15, 2014 | 08:07 PM
7T1vette's Avatar
7T1vette
If that is the ONLY thing you are going to do, then NO...it's not worth the effort and the RISK that you might end up with some leaks you presently do not have.
If you are going to do other engine work, and you don't want to spend money on a better cam, advancing the cam a bit MIGHT be worth the trouble.
Old Sep 15, 2014 | 08:23 PM
jb78L-82's Avatar
jb78L-82
I did exactly that cam advance by 4 degrees on my OEM L-82 cam when i did the timing chain and all it did was lower peak HP and torque by 500 RPM, hardly worth the effort if all you are doing is advancing the cam. I know the 78/79 L-82 had a factory aluminum intake and I thought the 80 L-48/L-82 as well but I might be wrong about the L-48's.
Old Sep 15, 2014 | 08:38 PM
Shark Racer's Avatar
Shark Racer
Stock appearing engines can be pretty quick...
Old Sep 15, 2014 | 08:54 PM
jb78L-82's Avatar
jb78L-82
Replace the heads, roller cam, everything else stock-no one will know:
Old Sep 15, 2014 | 10:27 PM
Joe Papa's Avatar
Joe Papa
I do not plan on replacing the camshaft; but the thought of advancing the camshaft and replacing the heads with maybe AFR or Summit aluminum units which are 50 state legal sounded entertaining. I figured the power band would be moved down (500 rpm) into a more useable area since I am limited to three speeds (auto) and better heads would still enhance the upper rpm band (5,500 rpm). Higher compression should also help all around. Do you think it would be still advantageous even though I am stuck with a 2-1-2 exhaust system (Flow Master with Magnaflow Cat Converter)?
Old Sep 16, 2014 | 07:42 AM
jb78L-82's Avatar
jb78L-82
Yes I think that changing the stock heads will always help. I have read good comments about the Summit aluminum heads. I don't think I would go AFR's without a combined parts replacement plan. As far as the 2-1-2 exhaust, it can made decent by what you have done with a high flow cat and free flowing mufflers but it will never match 2.5 inch true duals. There is a forum member out in your neck of the woods who has a 78 with 2-1-2 with 2.5 inch head pipes converging into a single 3.5 inch straight pipes where the cat is located and a 2.5 inch split pipes out back. This system will flow quite a bit better than the stock Y pipe and exhaust system. I think you would be very happy with the increased power.
Old Sep 16, 2014 | 08:33 AM
7t9l82's Avatar
7t9l82
IF you have the L-82 cam and IF you need to do the timing chain then yes advancing that cam is worthwhile. again IF you have that cam a good set of 64 cc chamber heads will boost compression and power. with that cam a set of 1.6 rockers will help and you would have a very drivable car with power just everywhere.
Old Sep 16, 2014 | 09:03 AM
Big Block Dave's Avatar
Big Block Dave
... Most of the power comes on above 3k rpm and is rather soft below. ..
Depending on where that powerband fades off, Id throw in a quality 3500 stall converter and have fun.
Old Sep 16, 2014 | 09:05 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
That cam is the same as the L46 cam but your engine is 9 to 1 and L46 was 11 to 1. L46 had 350 HP. A set of better flowing, aluminum small chamber heads will make a huge difference. That said the operating range of that cam is pretty high. Cure is lower gear differential or 2400 stall convertor. Advancing the cam will drop peak power and operating range.
Old Sep 16, 2014 | 05:39 PM
wilcar's Avatar
wilcar
I have used rhoads lifters on several engines where I had low speed driveability issues due to too much cam. They work as advertised.
Old Sep 16, 2014 | 07:10 PM
garygnu's Avatar
garygnu
if you remove the timing chain cover and balancer ,check to see what cam you have .if it is a stock GM cam ,maybe find a cam that will pass emissions and make good torque .great heads with a ok cam is better then a bigger cam only .
Old Sep 16, 2014 | 10:46 PM
Joe Papa's Avatar
Joe Papa
Wow, this is really great! I would like to say Thank You All for sharing your knowledge and experiences. I think I will leave the cam timing alone for now, since I really don't know what's in there. Sometime down the road I will probably spring for the Summit aluminum heads with 62cc combution chambers, possibly 1.6 ratio aluminum roller rockers and a 2,400 rpm stall lock up torque converter. I'm going to keep the 3:08's in the rear since I do cruise on freeway at times. I read somewhere that modern high stall torque converters of today do not slip at slow speeds like the old days; is this true even for a TH350c?
Old Sep 16, 2014 | 11:13 PM
bluedawg's Avatar
bluedawg
Im not for sure but I think the summit heads are dart Shp with the summit logo which do ok, but as Gary said great heads with an ok cam will pass emissions an make great torque and hp. There's other up grades that need to be done, but before we can go that wrote you'll need to know you applicable emissions laws.
oops!
Old Sep 17, 2014 | 12:43 AM
Joe Papa's Avatar
Joe Papa
oops!
Unfortunately in California, any car from 1975 and newer is subject to a biennial smog inspection. Everything has to be visually there, functioning properly during that time period and pass the sniffer test as well. The exhaust cannot be modified from the original 2-1-2 configuration; I'm all for clean air and would be willing to put on two cats to have a true dual system but the EPA and Air Rescources Board doesn't see it that way. This makes it very challenging in order to make improvements in both power and efficiency.
To Advancing Camshaft
Old Sep 17, 2014 | 01:34 AM
68post's Avatar
68post
2 - 2 &1/2" (mandrel-bent pipes only) into a single 3 1/2" is exactly what we used on a restricted class stock car.
With a high-flow cat it can be far better than an OEM original exhaust if there is room for it. IMHO
Would this flunk a visual inspection ?
We had to use iron manifolds too and 'vette ramhorns filled the bill nicely.
Do you any options for better manifolds or exempt headers ?
You may not make great improvements - but you may be able to make some.
Old Sep 17, 2014 | 03:09 AM
bluedawg's Avatar
bluedawg
Well the parts you buy need to have a carb number, you can do a little research about it at one of the local Im stations, buy the guy a few beers, ask some questions. Maybe go with 3" Madrel bent with a set of 2.5" rams horns with some extensive port work and bead blast through them some to smooth out the casting flaws, single oversized high flow cat, afr heads with a c.a.r.b. number, a roller cam with it as well, it would take a little research enginuity, work and tuning for emissions to past the pipe test but it's doable.
oops!
Old Sep 17, 2014 | 04:35 AM
Joe Papa's Avatar
Joe Papa
oops!
I could probably get away with some shorty style headers as long as they have the A.I.R. tubes installed in them. I haven't seen any 2.5" rams horns with A.I.R. tubes; wonder if it's possible to drill and tap into cast iron to install them so they at least look the part?
