Oil Level Hight ?
So how do I set the Oil Height ? If I could get a distance from the Oil Pan Rail to the Top of the Oil Level when full I could just match what You have.
540 RAT
Mechanical Engineer
U.S. Patent Holder
Member SAE (Society of Automotive Engineers)
Member ASME (American Society of Mechanical Engineers)
The independent and unbiased Engineering testing I perform to establish motor oil wear protection capability, is a dynamic friction test under load, similar to how an engine dyno test is a dynamic HP/Torque test under load. Both tests show how their subjects truly perform in the real world, no matter what Brand names are involved, no matter what outrageous claims may have been made, and no matter what their spec sheets say. You can see my entire 140+ motor oil “Wear Protection Ranking List”, which is "proven" by the Physics and Chemistry involved, and EXACTLY matches real world Track experience as well as High Performance Street experience (test data validation doesn’t get any better than this), along with additional motor oil tech FACTS, by going to the Blog link below.
This Blog now has over 75,000 views worldwide. Of course simply listing the number of views by itself, is not intended to indicate validation of the test data (validation is shown throughout the Blog). But, indicating the number of views does show that an enormous number of people worldwide recognize the value, understand the importance, and make use of the motor oil test data FACTS included here, that cannot be found anywhere else. And as a result, they are posting and sharing links to this Blog, all over the world. See for yourself.
The Blog includes:
Section 1 – Motor Oil Wear Protection Ranking List
Section 2 – Motor Oil Viscosity Selection
Section 3 – Motor Oil Thermal Breakdown Test Data
Section 4 - Component Quantity Lab Test Results
http://540ratblog.wordpress.com/
If you don't have any 'doco' on the pan, it's a little tougher. Does the pan 'look stock - no kick-out, etc', those are usually 6qt pans. If there is a kick-out, it usually goes up to 7qts. It's not going to be much more than that, since there is no room under the low sitting Corvette. But, that would be a good place to start.
Look at Jegs, etc for pics of their pans and see if any look close to yours and go from there. Keep in mind that unless you are racing it, missing the fill level by a little (6 qts in a 7qt pan) isn't going to be a real problem. If you have a cooler, etc, take that into consideration. But it would be best to know what pan you have and how much it holds.
Hope that helps.
Good luck.
walt z.
540 RAT
... cut ...
You don't want to run the engine before making the mark on the oil stick.
Pour in the amount specified for the pan, then make the mark, then run the engine, then refill to the mark.
The oil pan manufacturers state the capacity of their pans to achieve a certain height of oil under the crank.
The interesting question is what is this height?
Or alternatively, what is the optimum gap between the lowest pont of the crank and the oil level?
I believe I found information (but cannot verify source) that a 1/2" gap will provide enough depth of oil to prevent exposing the pump pick-up under cornering but not create excessive resistance to the rotating assembly.
This gap will obviously increase slightly when the engine is running as a certain volume of oil is always "up in the engine"!
Anyone got better detail on this??
