Part ID needed
Old Apr 23, 2015 | 03:58 PM
navet's Avatar
navet
Default Part ID needed
I am new to C3s. I found this part and have no idea what it is called. Or for that matter what it does
Old Apr 23, 2015 | 04:16 PM
blue by you's Avatar
blue by you
Looks like the over ride switch for the wipers and head lights
Old Apr 23, 2015 | 04:20 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
See number three below.. that's the vacuum switch in your picture. This mounts under the steering column.
Willcox
Old Apr 23, 2015 | 05:54 PM
Alan 71's Avatar
Alan 71
Hi n,
To add a bit to bby and Willcoxs' replies:
The pull down vacuum switch on the right opens the wiper door without turning the wipers on. (2 small vacuum hoses)
The middle electrical switch stops the wipers on the windshield. It's used for instance when changing the wiper blades. (2 fairly heavy gauge red wires in a single plug).
The pull down switch on the left opens the headlight doors without pulling the light switch. (2 small vacuum hoses).
Regards,
Alan
Old Apr 24, 2015 | 01:42 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by navet
...I am new to C3s...
Free unsolicited newbie advice: order the assembly instruction manual (AIM) for your model year. You may also want the chassis service manual.
To Part ID needed
