Am thinking about buying out of state 70 LS5 car but told block (289) is 72 with blank pad. Dealer says its most likely factory replacement and some blocks simply didnt have the CE stamp. True?? Never heard that one. Also, am told has original 70 heads and manifold. Do the 70 heads and manifold work with the 72 block? if the heads are correct, does that mean high compression pistons used? My concern is that this is still the high perf engine other than the block and not some watered down version. Would appreciate any advice. Thx.
Are you intending to purchase this car without seeing it? If you intend to inspect the car before writing the check, take someone with you to look over the engine.
Hi John,
Since the 3999289 block was used in car and truck applications and rated from 215 to 270 horsepower I don't think there's anyway of knowing what's in there at this point without taking it apart.
Almost every Chevrolet engine with no suffix code on the pad started life in a Corvette.
Regards,
Alan
Thanks for the responses. Before I take a long trip to see the car I just wanted to know if 70 heads and manifold can be used on a 72 block. And if so, is the only way to confirm the high compression pistons were used is to do a compression test? Would the 70 heads even work with the wrong 72 pistons? Just not sure how all the pieces could or could not fit together on this engine.
Hi John,
A compression test indicates the condition of the rings, valves and valve seats, not the compression rating.
The compression rating is a ratio determined mathmatically.
Regards,
Alan
The heads and intake will bolt up to a newer block. Those were closed chamber heads for 1970, high compression. No way to know what pistons are installed without taking it apart, not than I know of. You won't know what cam was installed either. I suggest you take it for a drive ir you're interested, see how it feels.
You may want to note the date codes on the castings, intake and heads if the owner will let you take of a valve cover. Also note the build date of the car as found on the trim tag. This may eliminate original heads and intake if the dates don't work out. Won't necessarily guarantee they're original.
Is there something special about this '70 LS5 that interests you? Could be a gamble for a NOM.
Good luck.
Some blocks had a clean deck with broach marks with no CE stamp. Believe it was used in dealer warrantee repair as was suggested. I had one, a E 5 1970 3963512 4 bolt main block that had all 427 internals, crank, pistons, rods correct for 1969 427 and both heads 1969 corvette dated 2 days apart W/ correct dated 390 HP intake. Believe the block was replaced under a warrantee repair using the original internals and heads.
Unless the seller can prove otherwise, assume it's a non matching #'s car. You are going to get into the whole, original, number correct or number matching debate. If it does not have the VIN #'s on the engine block, then it's not the original engine. Just my .02. Best of luck.
