Fouled Plugs
Old Jun 8, 2015 | 08:59 AM
jtalka's Avatar
jtalka
Default Fouled Plugs
Hi...
I'm running a ZZ383 in my 1978 PCR. Car runs really well. I recently pulled the plugs and much to my surprise, the left hand plugs were all fine while all of the right hand plugs looked to be fuel fouled... I also get a little smoke out of the right hand side pipe. I'm running a Holley 4150 750 dual feed, vacuum secondaries on top of an Edelbrock "air" manifold (air space between carb and the cam chamber)...
Any ideas???
Thx,
Joel
Old Jun 8, 2015 | 09:30 AM
zwede's Avatar
zwede
Maybe the intake gasket didn't seal on one side?
Old Jun 8, 2015 | 09:32 AM
hugie82's Avatar
hugie82
You'll want to look down the carb at idle and see if it's dripping.
Old Jun 8, 2015 | 09:46 AM
7T1vette's Avatar
7T1vette
Carb problem or intake gasket (on one side) problem.
Old Jun 8, 2015 | 10:06 AM
toobroketoretire's Avatar
toobroketoretire
Originally Posted by jtalka
Hi...
Any ideas???
Thx,
Joel
When a car is sitting slightly tilted to one side or the other fuel will drain into the lowest side during cold starts because raw gasoline collects on the bottom of the plenum then runs down the runners. Is your parking spot dead level or tilted a little bit?
Old Jun 8, 2015 | 10:24 AM
mikep3's Avatar
mikep3
Just thinking out loud, but I had a vacuum leak in my headlights system which is connected to the right side intake manifold. That made it run lean on one side and I over compensated by increasing the fuel on that side making the plugs foul.
I fixed the headlights and it works great now.
Old Jun 8, 2015 | 04:25 PM
7T1vette's Avatar
7T1vette
Reset your idle mixture and see if that helps any.
To Fouled Plugs
