1982 Collectors Edition Starting Problem
Old Jul 29, 2015 | 03:09 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Just stick a screw driver between the tow nuts on the solenoid and see if it turns over. If it doesn't then you have no power to the solenoid.
Old Jul 29, 2015 | 05:07 PM
rmichael63's Avatar
rmichael63
Originally Posted by 7T1vette
Apparently, you don't understand how the starter system works. The ignition switch (when turned to 'start' position) sends voltage to the STARTER SOLENOID; if the solenoid functions properly, it will send voltage to the starter. If it does not work properly, THERE WILL BE NO VOLTAGE SENT TO THE STARTER AND IT WILL NOT TURN.
If the Neutral Start Switch is bad, then NO VOLTAGE will be sent to the starter solenoid. That's why you need to check for voltage at the "S" terminal on the solenoid when the ignition key is turned to 'start' position.
This is my last attempt at trying to help you. It's a simple task to do the voltage check and, from the results, know what part to fix. If you choose not to do it, so be it.....
I understand what you said and have been saying. One of the other post said to try starting the car in neutral ... if it DID start then the neutral start switch is good and it's probably the solenoid or starter. I am going to check into the voltage thing you mention. Wow ... I didn't think I'd get attitude along with the very insightful post ...
Old Jul 29, 2015 | 10:50 PM
7T1vette's Avatar
7T1vette
The 'rudeness' was only due to your ignoring what was said. If I didn't want to help, I wouldn't have said anything.
Old Jul 30, 2015 | 06:44 PM
rmichael63's Avatar
rmichael63
Default Problem solved ...
First off thanks for all the input. I have had success with my starting problem.
As it turned out it was the starter so roughly $100 later I have my baby back up and running ...
Thanks again guys ...
Old Jun 7, 2019 | 04:51 AM
ColdLogic's Avatar
ColdLogic
Cruising
roadster- where do I find the "sticky" thanks ....James
