Spare tire lock removal
Old Jul 28, 2015 | 07:51 PM
Buddythedog's Avatar
Buddythedog
Default Spare tire lock removal
I need help and advice on how to remove the spare tire lock on my 72' in order to access my spare tire and have a key made. When I purchased the car, I was given only one key (ignition). I can see the tread pattern of the spare in the tub, and I am curious if it is the original speedway wide tread. Also, more importantly, if I get a flat tire while out driving, I will have to walk or get towed home.
Old Jul 28, 2015 | 07:58 PM
oldboat's Avatar
oldboat
try this
https://www.corvetteforum.com/forums...ck-remove.html
Old Jul 28, 2015 | 08:22 PM
Buddythedog
Will removing the two 9/16 bolts drop the tub and allow me to take the spare lock with it's assembly off the car so I can have a key made??
Old Jul 28, 2015 | 08:32 PM
65GGvert's Avatar
65GGvert
It's the same key as the door key. Could you have one made for the door and then use it to unlock the spare?
Old Jul 28, 2015 | 09:16 PM
Buddythedog
The ignition key can also be used to lock/unlock the doors. A second key is used for the rear compartment, burglar alarm, and spare tire lock which is the one I am missing.
Old Jul 28, 2015 | 09:37 PM
65GGvert's Avatar
65GGvert
You're correct, I confused myself. How about remove the lock from the rear compartment and have a key made? Easier than dropping all that other stuff.
Old Jul 28, 2015 | 11:40 PM
Iceaxe's Avatar
Iceaxe
Originally Posted by oldboat
I used the info in the thread noted to remove my lock. It took me about 10 minutes of playing around to pop the lock. Now I actually understand exactly what I'm doing it would take about 2 minutes. I never bothered to put the lock back on, it's in the box of old Corvette parts under the work bench.
Old Jul 29, 2015 | 07:44 AM
Alan 71's Avatar
Alan 71
Hi BtD,
Yes,
Removing the 2 bolts will allow the tub hanger bolt and lock to be removed as an assembly and give you access to the tire in the tub.
Regards,
Alan
Old Jul 31, 2015 | 02:52 PM
Buddythedog
Hi Alan,
Thanks for the info and accompanying pictures. Since I am a novice to C3 Corvettes, I have a couple of other possibly stupid questions.
1)Must the spare lock be removed from the assembly in order for a locksmith to fabricate a key.
2)Can the lock get damaged or destroyed in the process of key fabrication. I am trying to keep the car as original as possible.
Old Jul 31, 2015 | 03:04 PM
65GGvert's Avatar
65GGvert
I guess that means you didn't like the idea of removing the compartment lock and having a key made. It's the same key.
Old Jul 31, 2015 | 03:18 PM
Buddythedog
With a completely original interior, I don't want to risk damaging or having to replace any parts. On the other hand, the chassis area of the car is not all original, and I would prefer replacing the spare lock if necessary.
Old Jul 31, 2015 | 03:41 PM
rdroket's Avatar
rdroket
Old Jul 31, 2015 | 05:10 PM
Alan 71's Avatar
Alan 71
Hi Btd,
I believe a lock-smith can do his magic with the lock in place.
If you want to try 65's suggestion one phillips head screw releases the lock cylinder retainer from the glove box lid, then the cylinder slips out.
Good Luck!
Regards,
Alan
Old Jul 31, 2015 | 05:18 PM
65GGvert's Avatar
65GGvert
And as a bonus, you'll then have a key to your compartment and alarm.
To Spare tire lock removal
