Temperature
Old Aug 22, 2015 | 10:02 PM
news2me's Avatar
news2me
Default Temperature
I have a 77 with L-82, Auto trans with A/C. That's completely stock. My engine Temp runs from 190 to a tad over 200. Is that the normal temperature for C-3. What temperature are you guys running at.... Also, when I fill the radiator with anti freeze, should I top off the coolant bottle????
Old Aug 22, 2015 | 11:19 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I would say that's normal for your Vette. The overflow tank should have markings on it, both hot and cold.
Old Aug 22, 2015 | 11:52 PM
toobroketoretire's Avatar
toobroketoretire
The "coolant" bottle (aka coolant recovery tank or overflow tank) holds about 5 quarts of coolant and when the coolant is cold the coolant should only be about 1" deep. As the coolant heats up it expands and that tank will fill to as much as 3/4 full at full operating temperature.
Old Aug 23, 2015 | 07:39 AM
news2me's Avatar
news2me
Ok, on my coolant recovery tank there is a Cold and Hot marks. If the car is cold, I should fill the tank up with coolant to the Cold mark....
Old Aug 23, 2015 | 08:11 AM
65GGvert's Avatar
65GGvert
If you have the stock 195 thermostat, you're doing great. It will never run lower than 195 after warmup and that's the way it was designed.
Old Aug 23, 2015 | 09:56 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Yes. It's a nice sized recovery tank so it will easily take another quart or so on top of that.
To Temperature
