T Top weather strip....Any pointers?
I realize that in time, the new stripping will compress some, but how in the world would that affect the alignment of the panels?
Was thinking I'd loosen the nuts that hold the tabs and latches, and with the panels in place try and wiggle the alignment a bit better.
Any other thoughts on how to fix this?
I'll probably redo the t-tops with doc rebuild also as they sit a little high at the rear (weather strip is too stiff).
It could well be that the new weatherstrip needs to be compressed some; having the roof panel locked in place will do that.
There actually is quite a bit of adjustment available at 4 locations:
The 'probe' in the front outer corner has 2 twelve point bolts that move it around.
The 'wedge' at the rear outer corner moves the roof panel front to back, side to side, and up and down.
The 2 'tongues' on the center bar can be shimmed up and down and also have a bit of front to rear adjustment.
Also the way the front and rear locks/levers are adjusted affects how the panels fit too.
Good Luck!
Regards,
Alan
Front outer corner 'probe'.
Plate moves 'wedge' up and down, 'wedge's' threaded stud moves it forward and rearward.
Center 'tongue', front.
Center 'tongue', rear; note shims.
If I may jump in, my drivers side rear corner sits high about 1/8 of an inch.
Where would I start to lower it level with the sail?
I didn't think it needed a brand new thread.
Thanks,
Marshal
I'd first check to see if the 'wedge' on the body is seating fully in the slot in the 'receiver' in the rear corner of the roof panel.
If it is I'd then loosen the 2 screws in the plate which should allow the plate/'wedge' to move down slightly (unless it's already all the way down).
Also check to see if the adjustment on the locking lever's stud is pulling the panel down far enough.
Start with those 3.
Regards,
Alan
Here's the receiver. Make sure the wedge seats properly and that the white nylon guide is in place to prevent metal to metal contact. (Loud CREAK when going over railroad tracks!)
I'll let it sit for a while before trying anything else.
At this point the front window seals are giving me problems too. When you close the door, the glass hits the outer edge of the seal, and you have to push it in for the glass to seat as it should.
The kit I bought was Ecklers best ..........Whatever that means.
