Transmission upgrade?
Old Sep 6, 2015 | 01:15 PM
084273lz's Avatar
084273lz
Default Transmission upgrade?
1971 LS-6, over 600hp. The Muncie is not cutting it. I'm running 355's in the rear and at 70 its turning about 3000 rpm. Is a five speed my only option? what would be the cost on a TKO five speed out the door.
Thanks, John.
Old Sep 6, 2015 | 03:15 PM
cagotzmann's Avatar
cagotzmann
Thanks, John.
TKO 600 max torque is only 600 ftlbs. T56 Magnum is 700.
Hold out for a 6 speed conversion. This is a email I got from Silversport
Note the 6 speed conversion kit coming soon ?
http://campaign.r20.constantcontact....6-d4ae5292b9a6
I did a 3 speed auto to a Tremec T56 Magnum this last spring.
I used parts from a number of vendors with a few mods. The 6 speed (T56 Magnum) rated at 700 ftlbs will be a good fit for your engine.
https://www.corvetteforum.com/forums...-corvette.html
Old Sep 6, 2015 | 04:11 PM
GTOguy's Avatar
GTOguy
A much cheaper and easier option is to swap the 3.55's for some 3.08's. With your power and torque, you don't need a steep rear gear. 3.08's will put you right where you want to be in pretty much any driving situation.
Old Sep 6, 2015 | 04:18 PM
mrvette's Avatar
mrvette
AND I have a 308 R&P I willing to sell the OP.....send me a PM if interested......
Old Sep 7, 2015 | 10:43 AM
carbster09's Avatar
carbster09
What about a rebuild of your transmission with M-22Z gearing? Then you can run a 3.08 or even a 2.73. With that power and torque it should be no problem. cheaper too!
Check out Jody's Transmissions. I was thinking of doing the same in my build BBC
Old Sep 7, 2015 | 03:09 PM
Ibanez540r's Avatar
Ibanez540r
ONLY 600 TQ? Like that is not an impressive number compared to most trannies?
The 600 TQ comes from SUSTAINED testing, and as most manufacturer specs I assume is a SAFE number. Not many motors are going to hold that kind of TQ through the curve, rather peak for short times where the TKO will handle fine.
Either the 5 or 6 speed is a good choice. Make sure to calculate ratios with your rear gear to decide what suits your needs. The 5 speed has the same 1-4 with either a .63 or .82 OD. The 6 speed, I believe, comes in a wide and close ratio combination.
I pieced my "kit" together, but I think if you buy the ready to go TKO package your looking at around $4k
To Transmission upgrade?
